Does connecting PS/2 mouse to VGA adapter to HDMI adapter work?
Go to solution Solved by starsmine,
10 minutes ago, frnie said:
Sorry about the confusion there. I should've said it's a serial port. But from PS/2 to serial, would adding another converter from HDMI to serial work?
What you have pictured is VGA to HDMI (which also... doesnt really work without an active component somewhere)
Serial to HDMI wouldnt work in general unless its a non standard port, there isnt enough bandwidth
Thats svideo not ps/2. Thats for analog video conversion.
So yeah obviously not doesnt fit.
Also if someone made such an "adapter" it would obviously not work. A video signal doesnt carry an analog mouse/keyboard interface signal.
Now if you want to wire up and make something dumb like this yourself you can and can make it work actually. As log as you solder the hdmi pins to a ps/2 input port correctly you can do all of this bullshit as in the end you just created a very weird longer copper cable.
no that is a ps/2 port, the issue is the other side is a serial port, not a VGA port.
OP, if you want to hook up a PS/2 mouse to a modern PC, yea, use serial, be that... serial, or USB.
Oh yeah you're right that is serial. Quite hard to see on my phone. Darn you oled and pitch blacks :p.
What are you trying to do? Control your TV via mouse? 😉
9 minutes ago, frnie said:
How about ps/2 to serial female to serial male to serial male to serial female to audio???
what are you asking about here?
yes people have used the 3.5mm jack as serial, but that is very non standard, only a few devices ever did that.
Alright thank you. I think I got my answers here.
Can you explain what you are trying to do here? It will be easier to help you if we know the end goal.
No you can't just plug that in. Certain cameras use that for serial data transfer, for example, but that cable won't work with just anything
