Hello, all.
I recommended a close friend of mine a pre-built PowerSpec system from MicroCenter in Cleveland, if you're interested which build, here it is:
https://www.microcenter.com/product/669855/G717_Gaming_PC_Platinum_Collection;_AMD_Ryzen_7_7800X3D_42GHz_Processor;_NVIDIA_GeForce_RTX_4070_SUPER_12GB_GDDR6X;_32GB_DDR5-5600_RAM;_2TB_Solid_Stat
He got it all set up, and everything seemed to run just fine. He has a 1440p 180HZ monitor, and we played PUBG with zero issues. However, when we switched over to BO6, it was not a smooth experience for him. My PC is very similar (13600K with 32gb of 3600Mhz DDR4 and a 4070 Super) so I ran him through line by line in the settings to match mine. He's getting half of the frames that I am. Which, to me doesn't make a whole lot of sense, as his CPU is a much better gaming CPU than mine. I had him go into his BIOS and I confirmed Resize BAR was enabled, as well as XMPP/EXPO. All looked good on the BIOS. What else could it be? When he ran the benchmark tool in BO6, the performance summary said on the CPU side, the average FPS was 264, yet his average FPS on the GPU side was 87, which is awful. Is there something I could be missing?
Also, huge downside, I am in Houston, so all troubleshooting I have to do is via phone/discord/facetime. Any ideas or help is appreciated! Thanks.
Try a clean graphics driver uninstall with DDU (https://www.guru3d.com/download/display-driver-uninstaller-download/) and then reinstall it
Ryzen 7 5700X3D (-30 CO all-core) w/ cheap 6-pipe cooler - Gigabyte AX370-Gaming 5 - LPX 2x16GB 3600C18 2R - EVGA RTX 3070 8G XC3 PX1 - Patriot VPN110 1TB -  MSI A750GL - and a dogshit Sharkoon ATX case
Asus ROG G531GT : i7-9750H (-200 Vcore) - GTX 1650M +700mem - Samsung 16+8GB 2666 - 1920x1080@145Hz (172Hz) IPS panel
i5-6400 @4.3GHz (160 bclk) w/ Assassin King 120SE - Z170M-Plus - G.Skill 2x8GB 3200 C16 - Biostar RX 570 8G w/ MSI Armor cooler
i5-4690K + Z97-AR + Panram Blue Lightsaber 2x4GB PC3-2800
iMac 21.5" (late 2011) : i5-2400S, HD 6750M 512MB - Samsung 4x4GB PC3-1333 - WT200 512G SSD (High Sierra) - 1920x1080@60 LCD
Acer Z5610 "Theatre" C2 Quad Q9550 - 2x2GB PC3-1333 (Samsung) - 1920x1080@60Hz Touch LCD - great internal speakers
