Trying to overclock my AMD Phenom 9750 to 3.00Ghz plz help
Go to solution Solved by jaslion,
7 hours ago, SweetVanilla said:
Whattttttttttttttttttt, I feel like the cpu can go to 3.00ghz. I've got into windows on 3.00Ghz but kept getting blue screens. I feel like the ram or something else on the system is limiting it. If l can lower the memory clock and change something else that's needed l feel like l can get it stable.
I mean just check the forums from 2010 3ghz was considered EXTREMELY lucky. Plenty got em past the bios but none got em stable cept a few lucky ones
  • Specs
    • CPU - AMD Phenom 9750 2.4Ghz base
    • RAM - Random assortment of kingston memory 4, 2gb sticks of ddr2 running at stock 660-something speed
    • MOTHERBOARD- GA-MA780G-UD3H
    • PSU - 650w bronze msi power supply
  • Info
    • You might be asking, why the fuck would l do this now on such a old system.... For fun lol.
    • I got it to 2.8Ghz by changing the host clock control to 234Mhz and increasing the voltage to 1.3250v but the cpu clock ratio is capped at x12 and increasing the host clock anymore, ideally 250. I'll start running into memory problems l suspect or something else in the system needs extra voltage. If there's anyway to get the cpu to 3.00Ghz while also keeping the ram voltage to 2.000v or at best 2.100vs and something else probably needs extra voltage (l can't figure it out). That would be awesome!
Unless you got some REAL nice memory and one of THE LUCKIEST 9750's thrn you stand a chance.
Pretty much flat out getting a 9750 t0 3ghz is just not happening. Thesr phenoms gave you 400mhz extra tops if you were REAL lucky. Seems you are so nice on that but besides the 2.8ghz not much will happen.
So yeah unfortunatly this is as far as it will go basically.
