3 hours ago, testcy said:
Does it make sense to use a HDD in a 2.5" enclosure or should a SDD be the only option? I see that SEAGATE BARRACUDA PRO 1TB (ST1000LM049) costs about the same as CRUCIAL MX500 500GB (CT500MX500SSD1) and both seem to have the same warranty, which would you choose?
It makes sense or not kinda depends on what you need it for.
Example : If you need a portable drive, then it makes sense to use enclosure.
me, if I don't really really need that extra 400 something gb, I'd go SSD.
Iunno, after tasting moving 3TBs worth of datas to a portable ssd..... I don't think I can stomach to doing it to&from HDD.
Refresh before you reply
https://linustechtips.com/topic/1596730-drive-for-25-enclosure/#findComment-16626094
10 hours ago, Sant_HH said:
What do you plan to use the drive for?
Media backup and playback.
I am not asking if it makes sense to use an enclosure, but if it makes sense to use a HDD or a SSD in an enclosure. I understand the difference in speed, but more space can be useful.
https://linustechtips.com/topic/1596730-drive-for-25-enclosure/#findComment-16626166
Do you intend on moving large file on/off this often? If you do you will appreciate the extra speed that SSDs provide. But, if it's just for infrequent backups I'd deviate toward HDD.
Also, If you intend to travel with it a lot you have to be more careful with HDDs
Failure is part of success. I may make mistakes, that's how we all learn.
Please quote or @ me if you want me to be notified. Mark replies as answers if they solved your problem.
Folding at Home
https://linustechtips.com/topic/1596730-drive-for-25-enclosure/#findComment-16626447
