Internet is solid.聽
Cables are solid (swapped 2 cables - both are fine).聽
Direct connection to router (No middleman 馃檪)
Checked on other PC - solid.聽
Every 10 min or less, I get the globe icon showing up and I am loosing internet.聽
Is this a driver issue?聽
Anything else?
If driver, Windows update not showing any avaialble updates (nor in Optional).聽
How do I find the latest driver from the OEM?聽
Thanks!!!!
this is the ETH?
Sounds like a driver issue, and you are going to need to find more details about which ethernet controller you have. It's already hard enough to find a Realtek driver sometime it's a nightmare when you don't even know where to start the hunt for the driver.
In search of the future,聽new tech, and exploring the universe! All under the cover of anonymity!
thx. by device? where do i find the device/controller/hardware info?
You could check the detail under Device Manager, otherwise you could also look up your MOBO... I what I would say if I didn't just look at your post history and read that you have a laptop. Though you maybe able to research it from the laptop.
thank you.聽
can't check mobo cause this is a chinese branded mini PC
i am in device manager (see original post). what now?
thanks!!!!!!!!!!!!!!!!!!
So I am going to change my recommendation as I don't have the patience to refigure out how to find this info in Windows and I am going to recommend a third party utility called HWinfo
thank you friend!
