HGST Drives not turning on with 3.3V SATA power
Go to solution Solved by AbydosOne,
51 minutes ago, maateo0511 said:
I could put either electrical tape or Kapton tape, which is the best for reliability / is the safest?
Kapton would be the best choice. Scotch tape works in a pinch (mine wore through eventually and temporarily took down my array lol). I'd be worried that electrical tape would be too thick.
If you have insulation displacement connector (IDC) style SATA power plugs, you can unclip the back, wiggle the 3V3 wire out, and snap the cap back on. Tape over the exposed 3V3 wire and you're good to go.
Or be extra like me and design a custom SATA backplane PCB with jumper blocks to enable/disable 3V3 per drive...
Hello, I have recently bought some HGST drives on serverpartdeals, but I just realized that if it recieves 3.3V power it prevents it from powering on. From what I've seen , I could put either electrical tape or Kapton tape, which is the best for reliability / is the safest? I want to avoid SATA extension cables since those could fail and short.
Thanks for the help 🙂
any cable could in theory fail and short.
if you have kapton tape, that's the better option. it's more heat resistant, thinner, and stronger.
but i've defenately even sunk as low as painters tape to block off contacts on connectors.
but, what are you using to power the drives?
The PSU is a Seasonic B12 650W
Just now, Electronics Wizardy said:
You could also cut the 3v3 cable in the PSU sata cable. I don't think any recent drives have uses 3v3 power, and its not that hard to fix if needed later on.
The thing is that the PSU is brand new, still has warranty, I want to avoid modifying it for now
You wouldn't be modifying the PSU, just one of the modular cables. This won't matter, and you don't generally need the cables for warranty anyways with modular PSUs.
You also could just get the hard drives without the power disable "feature" WD does make them in both styles IIRC.
You can also pull the pin off the PSU-side connector so it can be put it back in if needed.
F@H
GPD Win 2
It's not modular lol, thanks for the advice though
Main System (Byarlant): Ryzen 7 5800X | Asus B550-Creator ProArt | EK 240mm Basic AIO | 16GB G.Skill DDR4 3200MT/s CAS-14 | XFX Speedster SWFT 210 RX 6600 | Samsung 990 PRO 2TB / Samsung 960 PRO 512GB / 4× Crucial MX500 2TB (RAID-0) | Corsair RM750X | Silicom (Intel) X540-AT2 10G NIC | Inateck USB 3.0 Card | Hyte Y60 Case | Dell U3415W Monitor | Keychron K4 Brown (white backlight)
Laptop (Narrative): Lenovo Flex 5 81X20005US | Ryzen 5 4500U | 16GB RAM (soldered) | Vega 6 Graphics | SKHynix P31 1TB NVMe SSD | Intel AX200 Wifi | Asus 2.5G USB NIC | Asus ProArt PA278QV | Keychron K12 Blue (RGB backlight)
Proxmox Server (Veda): Ryzen 7 3800XT | ASRock Rack X470D4U | Corsair H80i v2 | 64GB Micron DDR4 ECC 3200MT/s | 4× WD 10TB / 4× Seagate 14TB Exos / 8× WD 12TB (custom external SAS enclosure) / 2× Samsung PM963a 960GB SSD | Seasonic Prime Fanless 500W | Intel X550-T2 10G NIC | LSI 9300-8i HBA | Adaptec 82885T SAS Expander | Fractal Design Node 804 Case
Proxmox Server (La Vie en Rose)GMKtec Mini PC | Ryzen 7 5700U | 32GB Lexar RAM (SODIMM) | Vega 8 Graphics | Lexar 1TB 610 Pro SSD | 2× Realtek 8125 2.5G NICs
Media Center/Video Capture (Jesta Cannon): Ryzen 5 1600X | ASRock B450M Pro4 R2.0 | Noctua NH-L12S | 16GB Crucial DDR4 3200MT/s CAS-22 | EVGA GTX750Ti SC | UMIS NVMe SSD 256GB / TEAMGROUP MS30 1TB | Corsair CX450M | Viewcast Osprey 260e Video Capture | TrendNet (Marvell 88X3310P) 10G NIC | LG UH12NS30 BD-ROM | Silverstone Sugo SG-11 Case | Sony XR65A80K
Workbench (Doven Wolf): Lenovo m715q | Ryzen Pro 3 2200GE | 16GB Crucial DDR4 3200MT/s CAS-22 (SODIMM) | Vega 8 Graphics | SKHynix (OEM) 256GB NVMe SSD | uni 2.5G USB NIC | HDMI add-in module
Network:
                         ┌─────────────── Office/Rack ────────────────────────────────────────────────────────┐
Google Fiber Webpass ──── UniFi Cloud Gateway Max ═╦═ UniFi Flex XG ══╦═ Veda (Intel X550-T2.1)
(500Mbps↑/500Mbps↓)  (Asus USB 2½G NIC) Narrative ═╬═ La Vie en Rose  ╠═ Veda-NAS (Intel X550-T2.2)
                     (uni USB 2½G NIC) Doven Wolf ═╝  (Proxmox)       ╟─ UniFi Switch 8-60W ─┬─ Veda (IPMI)
╔═════════════════════════════════════════════════════════════════════╝                      └─ La Vie en Rose
║ ┌── Closet ───┐    ┌─────────────── Bedroom ────────────────────────────────────────┐
╚═ UniFi Flex XG ═╦╤═ UniFi Flex XG ═╤╦═ Byarlant (Silicom Intel X540-AT2)
           (PoE)  ║│                 │╠═ Narrative (Cable Matters 2½G NIC w/ USB-PD)
   Kitchen Jack ══╣└─ Dual PoE ┐     │╚═ Jesta Cannon* (Trendnet Marvell 88X3310P)
      (Testing)   ║┌─ Injector ┘     └── Work Laptop (Startech USB-PD Dock)
        Bedroom ══╝│
        Jack #2    │        ┌──────── Media Center ───────────────────────────────────┐
                   └──────── UniFi Switch 8 ────┬─ UniFi Access Point nanoHD (PoE)
Notes:                                          ├─ Sony PlayStation 4
─── is Gigabit / ═══ is Multi-Gigabit           ├─ Pioneer VSX-S520
* = cable passed from Bedroom to Media Center   └─ Sony XR65A80K (Google TV)
Perfect, I'll try and unclip the back, if I cant I'll go the Kapton route. Thanks so much 🙂
