CPU and GPU drop to 0% usage, causing 5 fps for about ten seconds
Go to solution Solved by 191x7,
12 hours ago, TheTubbyWhale1 said:
Asus prime a320-mk
The VRM on that trash board can't handle the R9 5950X. Who told you it was a good idea?
So while playing games my fps will suddenly drop to like 10 (The whole system, not just the game window) and my GPU and CPU usage drops to zero. I suspect two possible culprits but i would like a second opinion. I recently unpgraded to a 7800xt and this was running fine until today, when i upgraded from my r5 2600 to a r9 5950x. I've run multiple tests and it doesnt seem to do it when running benchmarks either. However, I only have a 650 watt power suply. I have ordered an 850 already anyway, but the GPU BRD PWR and CPU POWER also both drop instantly. Does anyone have any other ideas as to what could be causing this???
Which motherboard and which CPU cooler? Latest Bios?
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 30+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - HyperX Alloy Origins Core (TKL) - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Arcadyan ISP router - 35/5 Mbps vDSL
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
I know temperature isnt the issue because neither gpu or cpu go above 70, its probably not the most recent bios so i can try upating it. Asus prime a320-mk, Im going to upgrade it soon but i dont think the motherboard is causing the issue
Asus prime a320-mk
nobody told me it was a good idea, I just decided to put it in this board becauase its an am4 socket..So it should support all am4 chips?
Well thanks for the input anyway, Ive just said fuck it and ordered a new case and a new motherboard and a new PSU lmao so basically a new rig now
Which board did you order? Are you sure it's good for a 5950X? The 5950X is the second most power-drawing AM4 CPU, a good voltage regulation is a must-have.
I went with an asus b550-f gaming. From what i can see, this board should handle it fine. I will also likely upgrade to am5 at the end of the year as well, so no point in buying a 200+ am4 motherboard 🙂
