I recently bought a monitor LTT recommended on sale. I just got it and realized it has a faint grey grid pattern across the whole screen. I looked it up and this seems to be just something many OLEDs have. Why haven't LTT mentioned this? I've watched dozens of OLED videos from them and they've never mentioned this very important factor. It's something I can live with, but I should've been told about this considering they talk about burn-in on every video. It's not even about my situation. LTT are a major source of tech knowledge and I had this big blind spot because this was never brought up. I can't trust Linus Tech Tips to give me tips about tech! Is the world even round!?!
https://linustechtips.com/topic/1596064-oled-faint-grid-pattern/
I'm currently using an OLED TV (LG C4) and I don't see this. I mean I see the pixels layout if i get close, but I don't see any lines from afar. I've also used an OLED monitor before and never noticed this. Is it possible you got some refurbished/used monitor and got scammed?  Maybe you're using some weird subtype of OLED, I've only ever seen QD-OLED and WOLEDs, and I've never seen this issue.
First Computer: 3440x1440 @75Hz ROG STRIX 1080 Ti Core i5 8600K @ 1.415V @ 5.08 GHz Corsair Spec 02 EVGA CLC 280mm
This is abnormal, I think. There's a reason why YouTubers, LTT channel included, do not mention this in their videos. You should provide the exact model you have and where you got it from in your post. People might have a better idea of how to help you.
And if people confirm that they don't have it with their OLED monitors, it is time for you to contact support from the retailer you got it from.
I've got an OLED monitor, and I don't have that kind of problem with mine. You should contact support for warranty or return policy.
Corsair SF750 | FormD T1 V2.5 Black | Asus B650E-I ROG Strix Gaming Wifi | AMD Ryzen 7 7800X3D | 32GB 6000MHz Team T-Create | Asus RTX 4080 Super ProArt OC | MSI MPG 271QRX QD-OLED
R Λ Z Ξ R Viper V3 Pro | HHKB Professional HYBRID Type-S Charcoal Blank | Artisan Hayate-Otsu Soft | Beyerdynamic DT 990 Pro | JDS Labs Atom Stack | RØDE PodMic | RØDE AI-1
How and why is it LTT's responsibility to tell you everything about a purchase? They are under no obligation to tell you anything. If anything, it's on the manufacturer and you. Not a third party youtuber.
They reviewed it. If they badly review and thus make people buy a product without mentioning obvious things they see or covering it up thats on them fully.
Was there any proof that they noticed it or were covering it up? I didn't see any. If there was no malice or if they didn't notice something, that is not on them.
As Linus mentioned last Friday "It's my job to know." He wasn't referring to OLEDs but the principle is the same. They have multiple people who's job is monitors specifically.
I'll do that. I saw a post claiming support said this was normal but I'll check myself.
9 minutes ago, TinyGiraffes said:
this isnt normal, whats the monitor model
5950x 1.33v 5.05 4.5 88C 195w ll R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-24-2T (zen trfc)  1.45v 45C 1.15v soc ll 6950xt gaming x trio 325w 60C ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll 6x nf12/14 ippc fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll AW3423DW
9900k 1.36v 5.1avx 4.9ring 85C 195w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5500 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-30-280-20 ddr3666bdie 1.45v 45C 1.22sa/1.18 io  ll EVGA 30 non90 tie ftw3 1920//10000 0.85v 300w 71C ll  6x nf14 ippc 2000rpm ll 500gb nvme 970 evo ll l sandisk 4tb sata ssd +4tb exssd backup ll 2x 500gb samsung 970 evo raid 0 llCorsair graphite 780T ll EVGA P2 1200w ll w10p ll NEC PA241w ll pa32ucg-k
prebuilt 5800 stock ll 2x8gb ddr4 cl17 3466 ll oem 3080 0.85v 1890//10000 290w 74C ll 27gl850b ll pa272w ll w11
Unless you are still a child, it is also your job to have independent and critical thought. Don't trust a single source for information, know that people make mistakes, and understand that if someone doesn't tell you something it could not be from a place of malice.
Do you watch any other monitor reviews? Have any others mentioned the grid pattern? Are you attacking Monitors Unboxed the same way that you accuse LTT?
I know I sound like an old man yelling from my porch, but to think this was LTT's fault is ridiculous.
