Razer Viper V2 Pro 2 pin battery into 3 pin connector
Solved by SorryBella,
1 hour ago, ulookuglynoob said:Ok, Thanks! How do you think I can get a 100mAh battery or less on my Viper V2 Pro?
Not amazon. Try to check Aliexpress, the specification of connector you need is 3 pin JST 1mm. You'll also have to check the wiring and might have to shift the cables around to match stock because in Razer Viper Ultimate the polarities are not standard.
