How to setup openGL with dev C++ for using it with C?
By
VirusDumb
in Programming
in Programming
Solved by VirusDumb,
UPDATE:
Fixed the issue by simply selecting the 32 bit compiler for GCC which was just there infront of my eyes, all I had to do was select the 32 bit in compiler options while putting the linker commands and then using it from the drop down to run them
KeradSnake ·
Posted in Tech News0 -
3
4
5
gotopepik ·
Posted in CPUs, Motherboards, and Memory7 -
TedNukem ·
Posted in Programs, Apps and Websites3 -
13
n0rf114 ·
Posted in Power Supplies16 -
7
play_circle_filled
Latest From Linus Tech Tips:
I put a $3000 GPU in my Average PC... It Was a Mistake
