I am having Major difficulties finding a Wireless wifi kit
Go to solution Solved by Dicedcapp,
Its more the reviews that made me stay away from some of them, them half of them say its a savior the other half say its a total scam ill look into what you sent
My motherboard does not come with built in Wifi and bluetooth so before I build I want to have something to cover that before it becomes a bigger issue
The motherboard I have currently is a Asus Pro B550M-C/CSM Micro ATX AM4 Motherboard
People have suggested to use the Pcie instead but due to the size of the motherboard it is not possible so I have to use the m.2 E key.
I reside in Canada but the price change should not be too big of a concern.
There's plenty of laptop WiFi cards that will work on that board you can get, I'd just look for one of those and plug it in (the Intel AX210 is pretty common and cheap, looking on Amazon.ca at least), so you'd just need to get some antenna wires for it, though there's still plenty of those available. Something like this would be fine for not that much money:
https://a.co/d/dLSri0F
FYI, Ronothan## solved your issue, if you wanted to designate it as solved.
Onyx: AMD Ryzen 7 7800x3d / ASRock Taichi 7900xtx OC / Gigabyte B650 AORUS Pro AX / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Platinum Pro 850 / EK-AIO 360 Basic / Fractal Design North XL (black mesh) / AOC AGON 35" 3440x1440 100Hz / Mackie CR5BT / Corsair Virtuoso SE / Cherry MX Board 3.0 / Logitech G502
7800X3D - PBO -30 all cores, 4.90GHz all core, 5.05GHz single core, 18286 C23 multi, 1779 C23 single
Sage Ryzen 7800X3D - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 CL6000CL32 32GB - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.1Ghz - Gigabyte AORUS 1080Ti - Gigabyte AORUS Z370 Gaming 5 - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - EVGA SuperNova 650 P2 - Thermaltake Water 3.0 Ultimate 360mm - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Raven: AMD Ryzen 5 5600x3d - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200Mhz - XFX Radeon RX6650XT - Samsung 980 1TB + Crucial MX500 1TB - TP-Link AC600 USB Wifi - Gigabyte GP-P450B PSU -  Cooler Master MasterBox Q300L -  Samsung 27" 1080p
OnePlus Ecosystem:
Other Tech:
- Ubiquiti Amplifi HD mesh wifi
