B450M-HDV r4 no post
Solved by mariushm,
Put one stick at a time in the slot furthest away from the cpu socket.
To reset the bios settings, remove the battery and unplug the computer - while the computer is plugged in and power supply is turned on from the switch in the back, the power supply will continue to provide 5v stand-by, which can be used to keep the bios settings alive.
After a reset, it may take up to a minute or more to get image on the monitor as the bios may be "training" the memory stick(s), basically learning what timings work and all that. So basically be patient and don't turn off the pc if you don't get some image on the monitor right away, give it time.
