Got a problem, looking for solution
my setup:
ASUS ROG STRIX Z790-h GAMING WIFI DDR5
CPU : INTEL 13700K
RAM : DOMINATOR® TITANIUM RGB 64GB (2x32GB) DDR5 DRAM 6600MT/s CL32 Intel XMP Memory Kit
GPU : GeForce RTX™ 4060 Ti GAMING OC 8G
PSU : ROG STRIX 1000W GOLD AURA EDITON
So the problem is:
When i shut down my pc via windows, all looking good. All turned off as usual.
But when i starting my PC via button on front panel - it's dead, not booting at all, no sound, no coolers no led, nothing, and Bios Flashback LED staring blinking green on back panel. Constantly.
If i turned off PSU - Led turned off too, when i turn ON PSU - Led staring blinking again, and Power button on Front panel still not working.
Howdy there,
     Sometimes updating the BIOS on an ASUS mobo can be a royal PITA.  You need to cross all the T's and dot all the I's.  Below is what I found in the Asus mobo manual for your board.  I hope it helps.  Check out Chapter 3.4 on page 3.3 of the owners manual, maybe you can get some help there.
     You can find the English version of the mobo manual here:  https://rog.asus.com/us/motherboards/rog-strix/rog-strix-z790-h-gaming-wifi-model/helpdesk_manual/
When I attempted to restore the BIOS by adding a USB flash drive with the latest update, I also tried several older versions of the BIOS. When the fast green LED blinking finishes, it doesn't stop; instead, it returns to its default slow blinking. After a few moments, the system tries to restore the BIOS again. The situation resembles a never-ending loop of BIOS restoration.
I have uploaded a video on my YouTube channel explaining the details of my issue and the experiments I tried, but I haven't found a solution yet. I hope someone can help me solve the problem
