Budget (including currency): 1000€
Country: Latvia(Amazon not an good option cuz shipping expensive)
Games, programs or workloads that it will be used for: gaming/ streaming rig, small editing
Other details so can't decide to build am4 or Am5
If I build am5, have found ryzen 7 7700x as an good option cpu is around 280 euros
Gpu would probably go for rx 7800xt, but it's like 480 euro from the budget
Ram, MB, colling, psu is not an problem to find.
mostly need help on what platform generation to go and maybe go Intel, Nvidia 😅
Tnx for help
  • CPU
    Ryzen 5 1600 af 3.2 ghz
    Cooler AMD Wraith Prism rgb
  • Motherboard
    Asrock b450m-hdv r4.0
  • RAM
    16gb g.Skill 2666MHz
  • GPU
    Inoo3d 1650 super twin x2 oc
  • Case
    Genesis titan 750
  • Storage
    Kingston a400 240gb(system)
    Seagate barracuda 2tb 7200rpm(storage)
    Samsung 1tb 7200rpm(backup)
  • PSU
    Fsp si series 700w 50arn 88% efficiency
  • Display(s)
    Dell ultra sharp 24" 1080p
  • Cooling
    X4 Led case fans
  • Keyboard
    Redragon k552-rgb
  • Mouse
    Trust rgb gaming mouse
  • Sound
    Steelseries artic 1
  • Operating System
    Windows 10 home
https://linustechtips.com/topic/1592476-need-build-help/
How would an AM5 system look like?
current PC:
PC configs I used before:
https://linustechtips.com/topic/1592476-need-build-help/#findComment-16597522
Ryzen 7 7700x
RX 7800xt
1tb m.2
800w psu(or more if needed)
32gb ddr5 5600mhz ram
Cooling, do no air or aio
B650 motherboard
Case+fans
This would squeeze in the budget I think 😅
Something like this currently in my mind, maybe there's a better option 🙂 that's why I'm asking for help
  • CPU
  • Motherboard
  • RAM
  • GPU
  • Case
    Genesis titan 750
  • Storage
  • PSU
  • Display(s)
  • Cooling
    X4 Led case fans
  • Keyboard
    Redragon k552-rgb
  • Mouse
  • Sound
    Steelseries artic 1
  • Operating System
    Windows 10 home
https://linustechtips.com/topic/1592476-need-build-help/#findComment-16597531
best speed 6000Mhz + 32 or 30CL
you "think"?
It's a pretty decent plan, though on some parts the brand can start to matter a bit.
If you scour this site: https://de.pcpartpicker.com how far apart are the prices in your country? (it has Germany and few other countries)
current PC:
https://linustechtips.com/topic/1592476-need-build-help/#findComment-16597534
6 minutes ago, Bayron said:
Ryzen 7 7700x
RX 7800xt
1tb m.2
B650 motherboard
Case+fans
Add storage, a case and graphics card.
https://www.techspot.com/review/2728-ryzen-7500f-vs-core-13400f/
https://www.eurogamer.net/digitalfoundry-2023-amd-ryzen-5-7500f-review
https://www.balticdata.lv/lv/datortehnika/datoru-komponentes/pamatplates/pamatplate-asrock-a620m-pro-rs
ASRock A620M Pro RS €128.95
https://www.balticdata.lv/lv/datortehnika/datoru-komponentes/procesori/procesors--amd-ryzen-5-7500f
AMD Ryzen 5 7500F €166.95
https://www.balticdata.lv/lv/datortehnika/datoru-komponentes/dzesetaji/dzesetajs-arctic-freezer-36-co-black
Arctic Freezer 36 CO Black €39.95
https://www.balticdata.lv/lv/datortehnika/datoru-komponentes/operativas-atminas-ram/operativa-atmina-goodram-irdm-ddr5-32gb-black
Goodram IRDM DDR5-6000 32GB (2x16GB) CL30 €119.95
https://www.balticdata.lv/lv/datortehnika/datoru-komponentes/barosanas-bloki-psu/barosanas-bloks-msi-mag-a750bn-pcie5
MSI MAG A750BN PCIE5 ATX Power Supply €82.95
https://linustechtips.com/topic/1592476-need-build-help/#findComment-16597538
https://de.pcpartpicker.com/list/7M6kXR
Something like this(parts may be different in final build), but in my country it's cheaper(and more cheaper because I have some discounts etc in some shops), so it would be 1000€
  • CPU
  • Motherboard
  • RAM
  • GPU
  • Case
    Genesis titan 750
  • Storage
  • PSU
  • Display(s)
  • Cooling
    X4 Led case fans
  • Keyboard
    Redragon k552-rgb
  • Mouse
  • Sound
    Steelseries artic 1
  • Operating System
    Windows 10 home
https://linustechtips.com/topic/1592476-need-build-help/#findComment-16597540
3 minutes ago, Why_Me said:
Forget that build. It won't fit your budget. Look at AM4 Ryzen 5 5600 or LGA-1700 with a i5-12400F.
I could, baltic data is one of the expensive side shops in my region 😅
  • CPU
  • Motherboard
  • RAM
  • GPU
  • Case
    Genesis titan 750
  • Storage
  • PSU
  • Display(s)
  • Cooling
    X4 Led case fans
  • Keyboard
    Redragon k552-rgb
  • Mouse
  • Sound
    Steelseries artic 1
  • Operating System
    Windows 10 home
https://linustechtips.com/topic/1592476-need-build-help/#findComment-16597545
7 minutes ago, Why_Me said:
It's cheaper than Dateks.
Yes, but by searching local online shops I can cut some more euros, for example found mb for 113 euros etc
  • CPU
  • Motherboard
  • RAM
  • GPU
  • Case
    Genesis titan 750
  • Storage
  • PSU
  • Display(s)
  • Cooling
    X4 Led case fans
  • Keyboard
    Redragon k552-rgb
  • Mouse
  • Sound
    Steelseries artic 1
  • Operating System
    Windows 10 home
https://linustechtips.com/topic/1592476-need-build-help/#findComment-16597548
yeah that lowkey works, if the build really fits your budget,
to spend less you could get 7700, the X isn't important, if the build slightly exceeds your budget you could drop to 7600(x)/7500F and still have decent machine
the RAM really is good idea to go at least 32CL or 30CL but below 30CL is too much after that,
the Case and SSD could be bit better, the PSU actually could be slightly cheaper in some cases.
current PC:
https://linustechtips.com/topic/1592476-need-build-help/#findComment-16597551
Tnx, will see check some things whit your advices 😊
  • CPU
  • Motherboard
  • RAM
  • GPU
  • Case
    Genesis titan 750
  • Storage
  • PSU
  • Display(s)
  • Cooling
    X4 Led case fans
  • Keyboard
    Redragon k552-rgb
  • Mouse
  • Sound
    Steelseries artic 1
  • Operating System
    Windows 10 home
https://linustechtips.com/topic/1592476-need-build-help/#findComment-16597553
