I just got a MSI b650-s Wi-Fi motherboard and a kolink Observatory MX mesh and one of my friends said the fans cannot be controlled and it comes with some sort of weird connectors. There's the RGB one but then there's also this kind of daisy chain one if I should get them powered. But does anyone else know how to get this working? Thank you!
https://linustechtips.com/topic/1592457-how-to-control-fans/
Do you have a picture of the fans and connectors you are saying?
Some fans do have physical switches but you should still able to control them as regular 3pin fans via the motherboard (you may have to put the switch in the highest setting).
Unless it's a 12V powered fan...
Hence it would be nice to have a picture of the fan or known model.
https://linustechtips.com/topic/1592457-how-to-control-fans/#findComment-16597353
Using software or firmware? You should be able to control 3-pin fans from the BIOS and 4-pin fans through softwares such as Fan Control
The daisy chain's female header goes into 4-pin connectors with a dummy-proof tab that sticks out, whether it's 4-pin or 3-pin
Motherboard Fan Connectors: What They Are and How They Work
The RGB header goes into dedicated connectors as well
Single RGB fan connection confusion... | TechPowerUp Forums
Make sure they're plugged in correctly
Ryzen 7 5700X3D (-30 CO all-core) w/ cheap 6-pipe cooler - Gigabyte AX370-Gaming 5 - LPX 2x16GB 3600C18 2R - EVGA RTX 3070 8G XC3 PX1 - Patriot VPN110 1TB -  MSI A750GL - and a dogshit Sharkoon ATX case
Asus ROG G531GT : i7-9750H (-200 Vcore) - GTX 1650M +700mem - Samsung 16+8GB 2666 - 1920x1080@145Hz (172Hz) IPS panel
i5-6400 @4.3GHz (160 bclk) w/ Assassin King 120SE - Z170M-Plus - G.Skill 2x8GB 3200 C16 - Biostar RX 570 8G w/ MSI Armor cooler
i5-4690K + Z97-AR + Panram Blue Lightsaber 2x4GB PC3-2800
iMac 21.5" (late 2011) : i5-2400S, HD 6750M 512MB - Samsung 4x4GB PC3-1333 - WT200 512G SSD (High Sierra) - 1920x1080@60 LCD
Acer Z5610 "Theatre" C2 Quad Q9550 - 2x2GB PC3-1333 (Samsung) - 1920x1080@60Hz Touch LCD - great internal speakers
https://linustechtips.com/topic/1592457-how-to-control-fans/#findComment-16597354
But the issue is only cable I can seem to find is a male one
https://linustechtips.com/topic/1592457-how-to-control-fans/#findComment-16597371
5 minutes ago, MimoAW said:
I'm sorry the picture I sent was blurry but the connector I have is male those look female
Those I marked are supposed to be connected to the motherboard (if I got them right)
No idea what yours is (probably RGB stuff).
Edited by leclod
I'm willing to swim against the current.
https://linustechtips.com/topic/1592457-how-to-control-fans/#findComment-16597384
Okay this doesn't make too much sense then because the only cable I seem to have is this one. Fans are spinning but I cannot seem to control them and disconnects has been left loose
https://linustechtips.com/topic/1592457-how-to-control-fans/#findComment-16597394
If all fans are spinning then you're good. It doesn't matter if there's an extra header on the daisy-chain cable that isn't used.
Now it's just a matter of figuring out how to control your fans. Are they 3-pin or 4-pin fans?
https://linustechtips.com/topic/1592457-how-to-control-fans/#findComment-16597395
How do I find out? And also I don't know if this matters much but They're not actually plugged into anything on the front of the motherboard. They're plugged into something in the bag. I'm not sure what that something is
https://linustechtips.com/topic/1592457-how-to-control-fans/#findComment-16597397
Both 3-pin fans and 4-pin fans can be controlled by both Bios and FanControl
https://linustechtips.com/topic/1592457-how-to-control-fans/#findComment-16597493
For 3-pin fans it needs a PWM on the motherboard's header
Otherwise it's voltage-controlled solely by firmware
https://linustechtips.com/topic/1592457-how-to-control-fans/#findComment-16597499
I have trouble understanding you "needs a pwm" ?
Every motherboard I know of is able to deliver both PWM and DC power to its fans.
On my motherboard I have to set DC or PWM in the Bios depending on the fan type I'm using.
I currently manage 3 DC fans with FanControl (because the Arctic P12 is good and cheap)
Edited by leclod
https://linustechtips.com/topic/1592457-how-to-control-fans/#findComment-16597529
