Question about Corsair H115i RGB AIO fans and radiator
Solved by OddOod,
I have definitely done this, but not in a 4000D. This is a Phanteks p500 with the front rad connected by fans behind the front filter. I've also mounted fans that way in a p400. If they will fit behind the front mesh on the "outside" of the case, there is no reason not to do it, though you should absolutely double check that there is somewhere to route the fan cables into the case (if there ain't a hole, make a hole) so they can get power.
I even tested it and with a less deep radiator I could have mounted the rad outside and the fans inside, but sadly I got a thicc boi rad and was crunched for time
