"Power Supply does not provide a -12 V supply voltage" warning
Solved by seon123,
The -12V rail is optional. Unless you know you have something that uses -12V, you can just ignore it.
33 minutes ago, Anthrasite said:I find it very strange that PCPartPicker is filtering out this power supply and providing a warning about potential incompatibility when there doesn't appear to be any information about what this means online.
PCPP tends to prefer giving too many warnings, rather than too few warnings. They are just so you know some things to check for manually, not them telling you that something isn't compatible. They didn't show the RMx Shift for ages, due to the cables coming out of the side of it, despite lots of cases accomodating it without issue.
