CPU Utilization low while CPU Timings high causing entire system to lag
I always suggest setting IccMax for both the core and the cache to the max. That is 255.75 for your CPU. There is no reason to set IccMax to only 200.
5 hours ago, Frayed said:why it randomly happened
Either the BIOS is not setting the IccMax register correctly or some software on your computer is not setting IccMax correctly. Any software can change the IccMax value at any time. Are you running any MSI control software on your computer? Some of their software is a buggy mess.
Your FIVR screenshot shows that IccMax is set to the minimum, 1.00. That is why your CPU is constantly EDP throttling. The CPU is being forced to run as slow as possible, 800 MHz. It keeps running slower and slower as it desperately tries to reduce the current down to 1.00 Amps. That is impossible.
Why are you using ThrottleStop 9.5 when version 9.6 is available? Were you previously using ThrottleStop? Is it possible that you accidentally set IccMax to 1.00?
If you are interested in maximum performance, I would clear the Disable Controls box in the TPL window and I would set both PL1 and PL2 to at least 210. As long as you have good cooling, your CPU should be OK. If you want to run the 49 multiplier when all 8 cores are active, that is overclocking. Check the Overclock box in the FIVR window when you are overclocking.
Both log files you posted show severe EDP throttling with the CPU not running any faster than 800 MHz regardless of load. With all of the recommended settings above, run another log file and run another Cinebench test. Delete the previous log file so there is no confusion. A 9900K happily running Cinebench at 4900 MHz should have much better results compared to the same CPU stuck at only 800 MHz. There is no legit reason for any throttling of any kind during Cinebench unless that is what you want.
5 hours ago, Frayed said:I like mint green
Your color scheme is definitely not for me. Whatever makes you happy!
