Hopeing this finds someone who can help. I got my self a HP Prodesk 600 g2 (I5-6100 8GB DDR4 ram 256gb sdd 500hdd) for only 40eur. Setup proxmox and a couple of VM and Containers on it. Now the problem.
I noticed the fans are not loud but cause just enough sound to be annoying and when its quiet in the room can be easy heard. Since its in my room i was wondering if anyone can help with the fan control. I tried looking in the BIOS and only thing i found is idle fan speed % (that affects only the PSU fan for some reason). I tried sensors and fancontrol in proxmox but the fan is not detected. And by the looks of it the fan will be getting replaced. But before i go out and by a fan to lower the noise is there any program or options that i could try.
https://linustechtips.com/topic/1591876-hp-prodesk-600-g2-sff-fan-control/
We have about a hundred of these at work. They are terrible machines (USB ports die on them, sometimes they won't boot, ...).
Are you on the latest Bios (2.60)? If not, that might help.
If I recall correctly, the FAN headers they use are 3-pin, I'd have to check.
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 30+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - HyperX Alloy Origins Core (TKL) - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Arcadyan ISP router - 35/5 Mbps vDSL
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
