Budget (including currency): None
Country: USA
Games, programs or workloads that it will be used for: Mid-tier games
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): No parts yet, just have the old imac shell.
Biggest hurdles are getting a mobo small enough, making a new I/0 shield, and putting a 60hz screen in it.
https://linustechtips.com/topic/1591765-building-a-sleeper/
You will probably need a mini ITX motherboard. Should be able to get a smaller GPU in there also,  but you may need a riser to make it work. What price range for parts are you looking at?
My PC Specs: (expand to view)
Main Gaming Machine
CPU:  Intel Core i7-14700K
CPU Cooler: Deepcool LT720
Motherboard: MSI PRO Z790-P WIFI
Memory: G.Skill Trident Z5 RGB 32 GB (2 x 16 GB) DDR5-6400
Storage 1: Samsung 990 Pro 2 TB
Storage 2: Crucial P3 Plus 4 TB
Video Card: EVGA XC3 ULTRA GAMING GeForce RTX 3080 10GB
Power Supply: Corsair RM850 850W
Case: Corsair 7000D Airflow
Case Fan 140mm: Noctua A14 PWM 82.5 CFM 140 mm (x7)
Monitor Main: MSI G274QPF-QD 27.0" 2560 x 1440 170 Hz
Monitor Vertical: Asus VA27EHE 27.0" 1920x1080 75 Hz
https://linustechtips.com/topic/1591765-building-a-sleeper/#findComment-16592702
For screen, you should do measurement, go on panelook.com or some similar sites to find the right pick, then look on eBay. Some laptops may use the same size  and you either buy “Replacement parts" or buy a old one and salvage the screen.
As for motherboard set all i can say is good luck cuz it's no where near MODERN STANDARDS
https://linustechtips.com/topic/1591765-building-a-sleeper/#findComment-16592712
See its sites like that i was hoping to find here. As for mobo, irl people say mini itx and so far its the consensus here.
Im hoping to get a small gpu or orient the mobo so i can have a full sized card
https://linustechtips.com/topic/1591765-building-a-sleeper/#findComment-16592723
What is your plan for handling heat? Any AIOs or fans planned? Or are you just going to try to use pretty low powered hardware?
Main Gaming Machine
https://linustechtips.com/topic/1591765-building-a-sleeper/#findComment-16592731
Yeah nothing crazy powerful
Maybe a ryzen 7, 16gb ram, 1070 for gpu. There were two fans in it, so i may try for 3, plus the cpu cooler. Once i get it built ill run temp checks and circle back to alternative options if i need to
https://linustechtips.com/topic/1591765-building-a-sleeper/#findComment-16592784
Do you already have a 1070? A 4060 actually be a better option if you find a good deal used. Way lower TDP (so less heat) but performance is better than 1070 and has access to DLSS. I picked up a 4060 for 220 usd on fb market place a few weeks ago. 5700x3d is 203 USD on amazon right now.
Maybe something like this list: https://pcpartpicker.com/list/xvskXR
Main Gaming Machine
https://linustechtips.com/topic/1591765-building-a-sleeper/#findComment-16592814
