Final check on build
Solved by brob,
1 hour ago, someb0dys said:Thanks! I heard some horror stories of the wifi card already in the motherboard, are they true?
If you don't trust the included card, pick another motherboard
Hendrik__ ·
Posted in Troubleshooting0 -
Rujdaga ·
Posted in Laptops and Pre-Built Systems0 -
1
12
1
play_circle_filled
Latest From ShortCircuit:
I've wasted THOUSANDS of dollars... - Domesday Duplicator
