Budget (including currency): 1500 EUR (incl display, which costs ~210 eur where I live)
Country: Poland
Games: Arena Breakout Infinite 1440p 100+ fps; The Finals
Other details: My priorities are performance/$ (assuming DLSS 3 plays a big role here, plus ray tracing becomes mandatory soon?), quietness, easy temperature management;
gonna be my first ever complete build, since fidgeting with an old PC from school years
That's my draft build (adjusted - ram was missing):
https://de.pcpartpicker.com/list/jKhRkf
CPU: AMD Ryzen 5 8600G 4.3 GHz 6-Core Processor (€172.88 @ notebooksbilliger.de)
CPU Cooler: be quiet! Pure Rock 2 CPU Cooler (€36.89 @ Galaxus)
Motherboard: Gigabyte B650 GAMING X AX V2 ATX AM5 Motherboard (€161.90 @ Alza)
Memory: Corsair Vengeance 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory (€121.90 @ Amazon Deutschland)
Storage: TEAMGROUP MP33 512 GB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive (€38.70 @ Galaxus)
Storage: Western Digital WD_Black SN850X 1 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive (€86.16 @ Amazon Deutschland)
Video Card: MSI VENTUS 2X OC GeForce RTX 4070 SUPER 12 GB Video Card (€639.90 @ Alza)
Case: MSI MAG FORGE 120A AIRFLOW ATX Mid Tower Case (€71.90 @ Computeruniverse)
Power Supply: be quiet! System Power 10 850 W 80+ Gold Certified ATX Power Supply (€96.60 @ Galaxus)
Monitor: Dell G2724D 27.0" 2560 x 1440 165 Hz Monitor
Total: €1426.83
Hi, guys! Thank you for keeping this place alive - you provide incredible help to all the rookies (and I assume not only them), making the World a better place!
To all husbands and wives in the lobby - please, take off your rings, so you don't injure yourself with all the facepalming
Advisory needed #1 (CPU): 8600g vs 7600x,
7600x is more expensive and draws more power, which probably means tougher cooling. Will I get away with 8600g, i.e.
will it bottleneck MSI's 4070 super?
PCpp says i will need to update bios of the mb - can this be done as it is, or I will effectively need a cpu to run bios update and only then I can swap cpu to 8600g?
Advisory needed #2 (cooling):
Do I have enough cooling in general?
GPU has just 2 coolers, and will the case have enough airflow?
Will the selected cooler be enough for the 7600x as well as for 8600g?
Advisory needed #3:
In your opinion, should I go for Be quiet! products (psu, cpu cooler), chasing the low noise levels, or from experience there are better solutions for the price?
Thank you in advance for your time to at least partially address my concerns!
Have a wonderful day!
https://linustechtips.com/topic/1591653-new-build-cpu-temperature-noise-levels/
7600x all day everyday againts 8600g and the asus monitor is better than the dell one imo.
To be an expert is to know more about less.
  • 2014 Build --> FX 8350 4.7GHz {} ASRock Fatal1ty 990FX Killer {} Reference GTX 980 4GB {} 2x4GB 1866MHz HyperX {} Seagate 2TB 7200rpm {} 840 EVO 120GB {} XFX PRO850W {} Noctua NH D14 {} Fractal Define R4 White Windowed
  • 2018 Build --> Ryzen 7 2700X {} ASRock Fatal1ty X470 Gaming K4 {} Gigabyte RTX 2070 8GB {} 2x8GB HX Fury 3200MHz {} Toshiba P300 2TB {} Kingston 480GB A1000 {} Corsair RM750W {} Enermax LIQMAX II 240 {} Fractal Focus G
  • 2021 Build --> Ryzen 9 5900X {} ASUS ROG Strix X570-F GAMING {} ASUS GeForce RTX 3080Ti ROG STRIX OC {} Gigabyte AORUS RGB DDR4 32GB {} Kingston KC2500 M.2 2280 NVMe 2TB {} Seasonic FOCUS GX-1000 {} ASUS ROG Ryujin 240 AIO {} NYXT H710i
  • Laptop --> ASUS ROG STRIX G713RS {} Ryzen 9 6900HX {} 32GB DDR5 {} RTX 3080 {} 1TB NVMe {} Win 11 Home
20 minutes ago, greeatzy said:
7600x all day everyday againts 5600g and the asus monitor is better than the dell one imo.
Thanks for your advice re CPU! You meant 8600g though, right?
As for the proposed changes:
I guess I'd need to go for 32gb, as devs of ABI recommend 32gb for smoother experience, counting ssd on top, it already gets a bit expensive
Thanks for your opinion re monitor - I couldn't find it on rtings, unfortunately. I initially picked Dell for 450 cd/m2 brightness and nicer reviews vs competition. That Asus seems to have lower brightness at least per specs, but I'll look deeper into it!
sorry yes I meant 8600g but go with the 7600x.
try to fing 32gb for chep.. Its not like you're building a pc everyday.
Quote
Both displays are DisplayHDR 400 which means they must meet certain criteria like brightness which both of them do. Asus has a slightly better color accuracy from the box and its 180hz compared to 165hz. With both of them you wont go wrong in that price range I would say.
