White noise ( hiss ) Problem in Creative Stage SE mini
I purchased Creative Stage SE mini on 4/12/2024.
My speaker has a very loud hissing sound and I have tried the following steps but it has not helped to reduce this hissing sound. I would be grateful if you could provide a solution to reduce this problem
1. Replace the cable
2. Replace the speaker's power supply (the hissing sound is present whether it is connected to the computer with a USB cable or directly to the power supply and in Bluetooth mode)
3. Move the speaker to another location
4. Update the firmware and drivers
Creative USB Host Driver 3.01.11.00
Creative Stage SE mini FW v1.006
This is generally a characteristic of a class D or T amplifier. There is nothing you can do to reduce or remove it other than constantly play music to drown it out. Unfortunately the information is very absent in CL’s website, so I suspect it is not something they are proud of to advertise. This is unfortunately the way with modern devices. There are companies that improve the noise floor and others that do a better job controlling the hiss, but they are higher end models. Sorry I wish it was just your unit. But it’s all of them… don’t drive yourself crazy trying to fix it.
Dirty power.
Get yourself a line conditioner with surge suppression.
It should clean that up, maybe even give you a cleaner picture on your screen too.
AMD R9 5900X | Thermalright Frost Commander 140, NF-A14 3K, T30
Asus CH8 Dark Hero | 32GB G.Skill Trident Z @ 3733 14-14-14-34 1.5v
Zotac 4070 Ti Trinity OC @ 3045/1500 | WD SN850, SN850X, SN770
Vertex GX-1000 | Fractal Torrent Compact, 2x AL-180, TL-B14, TY-143
I wasn't aware of this being a "class D" kind of thing, class D are solid state and I thought were known as cleaner noise floor. Not sure what Class T is unless syou are using it for a Tube amplifier.
It is a very affordable soundbar so who knows what percent they put into making a good product and how much is a cash grab.
I'm assuming this is a new problem?
Open-Back -HiFiman Edition XS - AudioTechnica ATH-R70x Refine - Sennheiser 6xx - Focal Elex - Phillips Fidelio X3 - Harmonicdyne Zeus -  Beyerdynamic DT1990 - *HiFi-man HE400i (2017) - *Phillips shp9500 - *SoundMAGIC HP200
Semi-Open - Beyerdynamic DT880-600 - Fostex T50RP - *AKG K240 studio
Closed-Back - Rode NTH-100m - Meze 99 Neo - AKG K361-BT - Blue Microphones Lola - *Beyerdynamic DT770-80 - *Meze 99 Noir - *Blon BL-B60 *Hifiman R7dx
On-Ear - Koss KPH30iCL Grado - Koss KPH30iCL Yaxi - Koss KPH40 Yaxi
IEM - Tin HiFi T2 - MoonDrop Quarks - Tangzu Wan'er S.G - Moondrop Chu - QKZ x HBB - 7HZ Salnotes Zero
Headset *Turtle Beach Stealth 700 V2 + xbox adapter - *Sennheiser Game One - *Razer Kraken Pro V2
DAC S.M.S.L SU-9
Class-D dac/amp Topping DX7 - Schiit Fulla E - Fosi Q4 - *Sybasonic SD-DAC63116
Class-D amp Topping A70
Class-A amp Emotiva A-100 - Xduoo MT-602 (hybrid tube)
Pure Tube amp Darkvoice 336SE - Little dot MKII - Nobsound Little Bear P7
Audio Interface Rode AI-1
Portable Amp Xduoo XP2-pro - *Truthear SHIO - *Fiio BTR3K BTR3Kpro
Mic Rode NT1 - *Antlion Mod Mic - *Neego Boom Mic - *Vmoda Boom Mic
Pads ZMF - Dekoni - Brainwavz - Shure - Yaxi - Grado - Wicked Cushions
Cables Hart Audio Cables - Periapt Audio Cables
Speakers Kef Q950 - Micca RB42 - Jamo S803 - Crown XLi1500 (power amp class A)
*given as gift or out of commission
Unfortunately, this noise is also heard when playing music.
I also have another speaker, the T-DAGGER TGS600. It also has the hissing noise problem, but it is much less. You have to put your ear to the speaker to notice it.
How is it that in a much cheaper and less well-known product, this problem is less?
You assume CL is placing quality components in a $35 speaker? That Dagger has a 3w rating.
I’ve heard the complete opposite. Class A, B, or A/B have the lowest noise floors. Class D was historically in the cheapest products. They have improved significantly since ten years ago but it’s still not as good in cheaper products.
Absolutely not. But based on my research, this has nothing to do with the quality or price of your speaker.
The link below is an example of a $280 speaker.
https://www.reddit.com/r/WeAreTheMusicMakers/comments/ud7v1a/is_it_normal_for_studio_monitors_to_have_a_low/
Quote
I've had Fostex, Adam, Genelec and Dynaudio monitors. They all have a very low hiss if you crank the volume a bit and put your ear to the cone. That's thermal noise - all electronic circuits have a degree of that.
Quote
It's normal for it to be quiet, but you're saying you can hear it over the music so that's not good.
3 hours ago, johnt said:
Also, can you disable the Bluetooth? Even my A2+ speakers are noticeably hissy with the Bluetooth enabled.
Yes, I did that but the problem still exists.
