7 minutes ago, Platformer10101 said:
After lots of deliberation I have finally finished my parts list. the pricing on most of these is from deals I've secured but I want another opinion before I buy. pls give advice 馃槃
List:聽https://ca.pcpartpicker.com/user/Platformer10101/saved/JNYPzy
What's your actual budget?
But overall, not bad, I'd suggest getting a used 4060 TI instead though, I see quite a few in the 150$ mark.
https://linustechtips.com/topic/1591595-rate-my-parts-list/#findComment-16591476
I've been looking and I haven't found anything from Nvidia with this kind of performance to dollar value. Also, I live in Canada so 150 may be different for you and me. I don't rly have a budget I'm more or less just trying to keep my spending as low as possible
https://linustechtips.com/topic/1591595-rate-my-parts-list/#findComment-16591491
4060ti is like $250 ish used
1080 ti is like around $200 ish as well so hard to find gpus atm in Canada
so are you just buying ram and gpu? and have ther other stuff already?
Corsair Lian Li Bykski Barrow thermaltake nzxt aquacomputer 5v argb pin out guide + argb info
5v device to 12v mb header
Odds and Sods Argb Rgb Links
https://linustechtips.com/topic/1591595-rate-my-parts-list/#findComment-16591523
the only things I have right now are the ssd and peripherals. everything else I have to buy. I'm trying to conserve money so i think 150 on the gpu is good
https://linustechtips.com/topic/1591595-rate-my-parts-list/#findComment-16591525
nicer to have a list of what you got and dont so then i dont have to look for something i dont need to. i live in Canada so i no the prices a little better
so you have the m.2 and mouse and Headset right?
need to but a
case:
cpu:
gpu:
psu:
cooler:
ram:
right?
Edited by thrasher_565
https://linustechtips.com/topic/1591595-rate-my-parts-list/#findComment-16591527
need to but a
case:
cpu:
gpu:
psu:
cooler:
ram:
right?
I added a link to my pc park picker list in my original post heres the link:聽https://ca.pcpartpicker.com/user/Platformer10101/saved/JNYPzy
https://linustechtips.com/topic/1591595-rate-my-parts-list/#findComment-16591529
ya but im confused by it thats why im asking...
you have a cooler and then a price of $10 nexed to it. cant buy that for $10
if im going to spend my time looking i want it to count you no... doing just a bit more info can save me alot of time.
https://linustechtips.com/topic/1591595-rate-my-parts-list/#findComment-16591530
since I'm on a budget I'm getting most of my stuff second hand. I found a guy selling th CPU and he said for an extra $10 hell give me the cooler. So thats why the cooler is only $10
https://linustechtips.com/topic/1591595-rate-my-parts-list/#findComment-16591532
oh ok then. now i get it
https://linustechtips.com/topic/1591595-rate-my-parts-list/#findComment-16591533
$10 for the cooler is good as long as it has the mounting hardware
$100 for the cpu is problt right i guess
$100 for mb is fine
can save moeny on ram 16 gb is fine for a budget build
you have the m.2 already
$150 for gpu is what it is hard to fined better i guess
case is free? you have it or what? not the best case but not the worst i guess
psu also free? or what?
you have mouse and headphones.
need a keybord, monitor?
https://linustechtips.com/topic/1591595-rate-my-parts-list/#findComment-16591535
$100 for mb is fine
So for case and psu I'm getting them as a christmas gift. I already have peripherals but they're not the best
https://linustechtips.com/topic/1591595-rate-my-parts-list/#findComment-16591538
ya ied say if you want to save money on the ram or not up to you.
i would go with the cheapest 16gb ram. posalby even used off ebay. ram can be upgrade any time so...
i dont like msi but its probably fine and it probably was on sale at bf is my guess
i would have picked a slight better case but if its free its fine.
i thinking of futcher upgrades thats why spend a bit more now then latter is my thinking.
https://linustechtips.com/topic/1591595-rate-my-parts-list/#findComment-16591542
On 12/7/2024 at 3:14 PM, Zenny232323 said:
Same.
Go on ebay, buy now, free shipping and 210 canadian max(150usd). I found used 4060 ti's, you should too. Much better than a 5700xt
first one i found thats not a scam was $500 and it was an hp 4060 ti...and thats in the usa witch could add to the shipping...
https://linustechtips.com/topic/1591595-rate-my-parts-list/#findComment-16592820
