PC Part Pciker: https://pcpartpicker.com/list/t6NdmC
AMD Ryzen 5 5500
Stock Ryzen Cooler
AsRock B550m Wi-Fi se
ZOTAC RTX 3050 6gb
VENGEANCE LPX CMK 3200 179 16gb
Kingston Nv2 1TB
Corsair CV650
Macube 110
Games, programs or workloads that it will be used for:
Valorant
Roblox
Minecraft
CS2
Future Games:
WRC
F1
I am buying from a store and is limited to RTX cards otherwise would go for a 6600. Is this build good enough for the games?
https://linustechtips.com/topic/1591511-first-gaming-pc-review-600/
see if you can your hands on
a) a 5600(x) if you can, its significantly faster than the 5500
b) a RTX 20xx card, anything is better than the 3050. maybe they even have intel arc or maybe RX 5xxx?
otherwise i don't see any problems but i cant recommend improvements because i don't know what the store has.
