Samsung Monitor Va Panel Backlight Burned out?
Solved by Doobeedoo,
Oof, yeah I had one monitor like half of it was very dim, sometimes turning on off would work but eventually stopped and always one side is barely visible. Backlight dying. Can try lower brightness to min turn on off then set to max and see what happens. But yeah replacement.
You tried different cables, not sure about flicker part, I'd doubt it's to do with cable, GPU, driver issue at this point. Monitor backlight is is showing issue.
