Wi-Fi 6 AX200 160MHz : Has encountered an internal error and has failed
The last few weeks, my internet connection has been so unstable that it has caused system freezes during gaming, browsing, and even when accessing the Quick Settings in the taskbar. These freezes require a hard reset to resolve.
I tried troubleshooting and checked the Event Log, which showed the error: "Wi-Fi 6 AX200 160MHz: Has encountered an internal error and has failed."
To fix the problem, I:
  1. Updated to the latest OEM driver for the Wi-Fi card (didn't work).
  2. Updated to the latest generic driver (didn't work either).
  3. Updated the BIOS and chipset drivers (also didn't work).
I have seen other people have the same problem but never understod how they resolved it. I would rather not reinstall windows and have hear it dose not fix the issue. I have no ide what to do.
Minidump.zip
My AX200 went flakey on me a few months ago. They're not too expensive to replace outright, which is what "fixed" mine.
Main System (Byarlant): Ryzen 7 5800X | Asus B550-Creator ProArt | EK 240mm Basic AIO | 16GB G.Skill DDR4 3200MT/s CAS-14 | XFX Speedster SWFT 210 RX 6600 | Samsung 990 PRO 2TB / Samsung 960 PRO 512GB / 4× Crucial MX500 2TB (RAID-0) | Corsair RM750X | Silicom (Intel) X540-AT2 10G NIC | Inateck USB 3.0 Card | Hyte Y60 Case | Dell U3415W Monitor | Keychron K4 Brown (white backlight)
Laptop (Narrative): Lenovo Flex 5 81X20005US | Ryzen 5 4500U | 16GB RAM (soldered) | Vega 6 Graphics | SKHynix P31 1TB NVMe SSD | Intel AX200 Wifi | Asus 2.5G USB NIC | Asus ProArt PA278QV | Keychron K12 Blue (RGB backlight)
Proxmox Server (Veda): Ryzen 7 3800XT | ASRock Rack X470D4U | Corsair H80i v2 | 64GB Micron DDR4 ECC 3200MT/s | 4× WD 10TB / 4× Seagate 14TB Exos / 8× WD 12TB (custom external SAS enclosure) / 2× Samsung PM963a 960GB SSD | Seasonic Prime Fanless 500W | Intel X550-T2 10G NIC | LSI 9300-8i HBA | Adaptec 82885T SAS Expander | Fractal Design Node 804 Case
Proxmox Server (La Vie en Rose)GMKtec Mini PC | Ryzen 7 5700U | 32GB Lexar RAM (SODIMM) | Vega 8 Graphics | Lexar 1TB 610 Pro SSD | 2× Realtek 8125 2.5G NICs
Media Center/Video Capture (Jesta Cannon): Ryzen 5 1600X | ASRock B450M Pro4 R2.0 | Noctua NH-L12S | 16GB Crucial DDR4 3200MT/s CAS-22 | EVGA GTX750Ti SC | UMIS NVMe SSD 256GB / TEAMGROUP MS30 1TB | Corsair CX450M | Viewcast Osprey 260e Video Capture | TrendNet (Marvell 88X3310P) 10G NIC | LG UH12NS30 BD-ROM | Silverstone Sugo SG-11 Case | Sony XR65A80K
Workbench (Doven Wolf): Lenovo m715q | Ryzen Pro 3 2200GE | 16GB Crucial DDR4 3200MT/s CAS-22 (SODIMM) | Vega 8 Graphics | SKHynix (OEM) 256GB NVMe SSD | uni 2.5G USB NIC | HDMI add-in module
Network:
                         ┌─────────────── Office/Rack ────────────────────────────────────────────────────────┐
Google Fiber Webpass ──── UniFi Cloud Gateway Max ═╦═ UniFi Flex XG ══╦═ Veda (Intel X550-T2.1)
(500Mbps↑/500Mbps↓)  (Asus USB 2½G NIC) Narrative ═╬═ La Vie en Rose  ╠═ Veda-NAS (Intel X550-T2.2)
                     (uni USB 2½G NIC) Doven Wolf ═╝  (Proxmox)       ╟─ UniFi Switch 8-60W ─┬─ Veda (IPMI)
╔═════════════════════════════════════════════════════════════════════╝                      └─ La Vie en Rose
║ ┌── Closet ───┐    ┌─────────────── Bedroom ────────────────────────────────────────┐
╚═ UniFi Flex XG ═╦╤═ UniFi Flex XG ═╤╦═ Byarlant (Silicom Intel X540-AT2)
           (PoE)  ║│                 │╠═ Narrative (Cable Matters 2½G NIC w/ USB-PD)
   Kitchen Jack ══╣└─ Dual PoE ┐     │╚═ Jesta Cannon* (Trendnet Marvell 88X3310P)
      (Testing)   ║┌─ Injector ┘     └── Work Laptop (Startech USB-PD Dock)
        Bedroom ══╝│
        Jack #2    │        ┌──────── Media Center ───────────────────────────────────┐
                   └──────── UniFi Switch 8 ────┬─ UniFi Access Point nanoHD (PoE)
Notes:                                          ├─ Sony PlayStation 4
─── is Gigabit / ═══ is Multi-Gigabit           ├─ Pioneer VSX-S520
* = cable passed from Bedroom to Media Center   └─ Sony XR65A80K (Google TV)
If i where to replace it should i use a genric or the OEM driver?
35 minutes ago, BillBill said:
You can use the driver direct from intel or your motherboard manufactures website.
Assuming you replace it with another AX200, you'll already have the driver installed.
Network:
        Bedroom ══╝│
2 hours ago, BillBill said:
Not even sure if the wi-fi card is defective.
people have had the same problem as far back as 3 years. People fixed their problem by re roling their drivers. Is there value in trying to find a older driver?
If an older driver works then it's sure is worth it.
I had a Realtek wi-fi that CONSTANTLY had issues, to the point where Windows stopped detecting the wi-fi device entirely, not showing up at all in device manager.
Had to do a windows repair which was its own set of complication to get working, then cloning disks to have a working backup.
The microsoft branded driver actually worked better than the realtek, but it broke it by using it as a hammer on a rigid table, and am unable to re-assemble it.  Such an aggravation.
And I know it isn't the hardware just the horrendously poor drivers that ruin the ability to use it.
Multiple times A DAY, I would have to disable the device and re-enable it for it to work again, then even that stopped working so I had to work through how to do a Windows repair, which is not easy.
Cheap wireless devices are not worth anyone's time nor frustration.
: JRE #1914 Siddarth Kara
How bad is e-waste?  Listen to that Joe Rogan episode.
"Now you get what you want, but do you want more?
- Bob Marley, Rastaman Vibration album 1976
Windows 11 will just force business to "recycle" "obscolete" hardware.  Microsoft definitely isn't bothered by this at all, and seems to want hardware produced just a few years ago to be considered obsolete.  They have also not shown any interest nor has any other company in a similar financial position, to help increase tech recycling whatsoever.  Windows 12 might be cloud-based and be a monthly or yearly fee.
Software suggestions
Just get f.lux [Link removed due to forum rules] so your screen isn't bright white at night, a golden orange in place of stark 6500K bluish white.
released in 2008 and still being improved.
Dark Reader addon for webpages.  Pick any color you want for both background and text (background and foreground page elements).  Enable the preview mode on desktop for Firefox and Chrome addon, by clicking the dark reader addon settings, Choose dev tools amd click preview mode.
NoScript or EFF's privacy badger addons can block many scripts and websites that would load and track you, possibly halving page load time!
F-droid is a place to install open-source software for android, Antennapod, RethinkDNS, Fennec which is Firefox with about:config, lots of performance and other changes available, mozilla KB has a huge database of what most of the settings do.  Most software in the repository only requires Android 5 and 6!
I recommend firewall apps (blocks apps) and dns filters (redirect all dns requests on android, to your choice of dns, even if overridden).  RethinkDNS is my pick and I set it to use pi-hole, installed inside Ubuntu/Debian, which is inside Virtualbox, until I go to a website, nothing at all connects to any other server.  I also use NextDNS.io to do the same when away from home wi-fi or even cellular!  I can even tether from cellular to any device sharing via wi-fi, and block anything with dns set to NextDNS, regardless if the device allows changing dns.  This style of network filtration is being overridden by software updates on some devices, forcing a backup dns provuder, such as google dns, when built in dns requests are not connecting.  Without a complete firewall setup, dns redirection itself is no longer always effective.
