Why my mini led monitor has less contrast and colors than my IPS ?
Hi
I have two monitors benq ips and koorui GN10 mini led but I see the text and colors are better in benq more than the koorui. I am not sure if I should change something in the OSD. Also want to ask which has better colors and details mini led or quantum dot ?
Thanks
Mini led only means the backlight is an array of a lot of small LEDs, the panel in front can just as much be good or garbage.
Best to look at actual reviews to know how good a specific monitor is or isn't.
F@H
GPD Win 2
6 minutes ago, William2345 said:
I did that , many say good things about koorui gn10
What is the backlight dimming setting?
Are you watching HDR or SDR content?
If you show only back in a dark room can you see any backlight?
I have local dimming on (it is on or off)
I use SDR , HDR is too bright for my eyes
what show only back mean ?
Quickly perusing various Reddit threads, is sure reads like this thing may need some calibration out of the box. Maybe read some more to see if you can get someone's ICC profile or buy the calibration hardware? Personally I'd rather spend a little more and get something well calibrated out of the box. Have you played around with the OSD?
Ryzen 7 7800x3D -  Asus RTX4090 TUF OC- Asrock X670E Taichi - 32GB DDR5-6000CL30 - SuperFlower 1000W - Fractal Torrent - Assassin IV - 42" LG C2
Ryzen 7 5800x - XFX RX6600 - Asus STRIX B550i - 32GB DDR4-3200CL14 - Corsair SF750 - Lian Li O11 Mini - EK 360 AIO - Asus PG348Q
