So this is how it looks like now:IMG20241205021627.thumb.jpg.4f829bc165995c7a01fc0bb845dd2eae.jpg
So first I added 1cm spacers to make the 47mm low profile cooler fit in a case rated for 37mm cooler. But recently I was reading something about fan noises, and it seems quite a bit of sharp noise is caused by the upper panel grills too close to fan and cause windshear, so I grabbed the spare bag of spacers and added another 1cm on top of the old one and the noise went away like magic
https://linustechtips.com/topic/1591355-added-extra-spacer-to-reduce-fan-noise/
Well done. Similar to how the Fractal Terra can sound.
Onyx: AMD Ryzen 7 7800x3d / ASRock Taichi 7900xtx OC / Gigabyte B650 AORUS Pro AX / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Platinum Pro 1000 / EK-AIO 360 Basic / Fractal Design North XL (black mesh) / AOC AGON 35" 3440x1440 100Hz / Mackie CR5BT / Corsair Virtuoso SE / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
OnePlus Ecosystem:
Other Tech:
