Hi. I have a 5800X3D on a Asus B350 ROG Strix that boosts just fine, so yours should too.
Heat, power and BIOS are the three most likely things that will prevent boosting.
How are your temps? If they are high it will be an issue.
Do you have any overclocking utilities installed? AMD's Ryzen Master Utility, for example. If so, try uninstalling them, then rebooting.
Have you tried clearing CMOS/BIOS? If not, please try.
