Noticeably loud coil buzz whenever I do anything
in Troubleshooting
Yeah it's probably the graphics card. It's a fairly well known thing with them.
Run something like Prime95 - it uses no GPU, so unless you scroll the screen, you should hear no noise as it computes. If you do hear the noise, it's more likely to be the RAM.
Blizzforte ·
Shockboost99 ·
Posted in Troubleshooting0 -
Mineplayz ·
Posted in CPUs, Motherboards, and Memory2 -
melontek ·
Posted in Laptops and Pre-Built Systems0 -
9
Peter_The_Ent ·
Posted in Graphics Cards11 -
2
melontek ·
4
AnnuEnDag ·
Posted in CPUs, Motherboards, and Memory9
