Issues assigning GPU to Jellyfin on TrueNAS Scale 24.10
Go to solution Solved by will0hlep,
To anyone else with this issue:
try this, seems to have worked for me
https://forums.truenas.com/t/unable-to-use-nvidia-gpu-with-jellyfin-after-24-10-upgrade/21996/21
How do I assign the RTX 2060 in my NAS to the Jellyfin app?
I've set it up as an isolated GPU, which apparently I need to do for apps to use it, but In the edit apps screen I have no option to add GPU resources to Jellyfin.
(Worked out that Isolating GPUs is for VMs, not apps, still stuck though)
I might be experienced, but I'm human and I do make mistakes. Trust but Verify! Expand for common PC building advice, a short bio and a list of my components and other tech. I edit my messages after sending them alot, please refresh before posting your reply. Please try to be clear and specific, you'll get a better answer. Please remember to mark solutions once you have the information you need.
Common build advice: 1) Buy the cheapest (well reviewed) motherboard that has the features you need. Paying more typically only gets you features you won’t use. 2) only get as much RAM as you need, getting more won’t (typically) make your PC faster. 3) While I recommend getting an NVMe drive, you don’t need to splurge for an expensive drive with DRam cache, DRamless drives are fine for gamers. 4) paying for looks is fine, just don’t break the bank. 5) Tower coolers are usually good enough, unless you go top tier Intel or plan on OCing. 6) OCing is a dead meme, you probably shouldn’t bother. 7) "Bottlenecks" rarely matter and "Future-proofing" is a myth. 8) AIOs don't noticably improve performance past 240mm.
useful websiteshttps://www.productchart.com - helps compare monitors, https://uk.pcpartpicker.com - makes designing a PC easier.
He/Him
I'm a PhD student working in the fields of reinforcement learning and traffic control. PCs are one of my hobbies and I've built many PCs and performed upgrades on a few laptops (for myself, friends and family). My personal computers include 3 windows (10/11) machines and a TrueNAS server (and I'm looking to move to dual booting Linux Mint on my main machine in future). While I believe I have an decent amount of experience in spec’ing, building and troubleshooting computers, keep in mind I'm not an expert or a professional and I make mistakes.
Favourite Games of all time: World of Tanks, Runescape, Subnautica, Metroid (Fusion and Dread), Spyro: Year of the Dragon (Original and Reignited Trilogy), Crash Bash, Mario Kart Wii
Main PC: https://uk.pcpartpicker.com/user/will0hlep/saved/NByp3C
Secondary PC: https://uk.pcpartpicker.com/user/will0hlep/saved/cc9K7P
TrueNAS Server: https://uk.pcpartpicker.com/user/will0hlep/saved/m37w3C
Laptop: 13.4" ASUS GZ301ZE ROG Flow Z13, WUXGA 120Hz, i9 12900H, 16GB DDR5, 1TB NVMe SSD, 4GB RTX 3050 Ti, TB4, Win11 Home, Used with: 2*ThinkPad Universal Thunderbolt 4 Dock, Logitech G603, Logitech G502 Hero, Logitech K120, Logitech G915 TKL, Xbox Elite Wireless Controller Series 2, Logitech G PRO X Gaming-Headset (with Blue Icepop in Black), {specs to be updated: two monitors}
Other: LTT Screwdriver, LTT Stubby Screwdriver, IFIXIT Pro Tech Toolkit, Playstation 1 SCPH-102, Playstation 2 SCPH-30003, Gameboy Micro Silver OXY-001, Nintendo Wii U WUP-001(03), Playstation 4 CUH-1116A, Nintendo Switch OLED HEG-001, Yamaha RX-A4A Black AV Receiver, Monitor Audio Radius (4*90s, 1*200s, 2*270s, 1*380s), TP-Link TL-SG105-M2, Netgear GS308, IPhone 14 Pro Max 128GB Space Black, Secretlab TITAN Evo (Black SoftWeave Plus Fabric), 2*CyberPower BR1200ELCD-UK BRICs Series, Samsung 40" ES6800 Series 6 SMART 3D FHD LED TV, UGREEN USB 3.2 Gen 2 10Gbps M.2 NVMe SSD Enclosure, SABRENT 3.5" SATA drive docking station
I've also just found the "Install Nvidia Drivers" tickbox but that didn't seem to help either.
He/Him
Okay, managed to make progress. I now have a "Use this GPU" tickbox in the edit app settings under my RTX 2060. But If I tick it and hit update I get the following error.
error FAILED
[EFAULT] Failed to render compose templates: Traceback (most recent call last): File "/usr/bin/apps_render_app", line 33, in sys.exit(load_entry_point('apps-validation==0.1', 'console_scripts', 'apps_render_app')()) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/catalog_templating/scripts/render_compose.py", line 47, in main render_templates_from_path(args.path, args.values) File "/usr/lib/python3/dist-packages/catalog_templating/scripts/render_compose.py", line 19, in render_templates_from_path rendered_data = render_templates( ^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/catalog_templating/render.py", line 36, in render_templates ).render({'ix_lib': template_libs, 'values': test_values}) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/jinja2/environment.py", line 1301, in render self.environment.handle_exception() File "/usr/lib/python3/dist-packages/jinja2/environment.py", line 936, in handle_exception raise rewrite_traceback_stack(source=source) File "/mnt/.ix-apps/app_configs/jellyfin/versions/1.1.7/templates/docker-compose.yaml", line 3, in top-level template code {% set c1 = tpl.add_container(values.consts.jellyfin_container_name, "image") %} ^^^^^^^^^^^^^^^^^^^^^^^^^ File "/mnt/.ix-apps/app_configs/jellyfin/versions/1.1.7/templates/library/base_v2_0_21/render.py", line 53, in add_container container = Container(self, name, image) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/mnt/.ix-apps/app_configs/jellyfin/versions/1.1.7/templates/library/base_v2_0_21/container.py", line 63, in __init__ self.deploy: Deploy = Deploy(self._render_instance) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/mnt/.ix-apps/app_configs/jellyfin/versions/1.1.7/templates/library/base_v2_0_21/deploy.py", line 15, in __init__ self.resources: Resources = Resources(self._render_instance) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/mnt/.ix-apps/app_configs/jellyfin/versions/1.1.7/templates/library/base_v2_0_21/resources.py", line 24, in __init__ self._auto_add_gpus_from_values() File "/mnt/.ix-apps/app_configs/jellyfin/versions/1.1.7/templates/library/base_v2_0_21/resources.py", line 55, in _auto_add_gpus_from_values raise RenderError(f"Expected [uuid] to be set for GPU in slot [{pci}] in [nvidia_gpu_selection]") base_v2_0_21.error.RenderError: Expected [uuid] to be set for GPU in slot [0000:01:00.0] in [nvidia_gpu_selection]
remove_circle_outlineMore info...
Error: Traceback (most recent call last): File "/usr/lib/python3/dist-packages/middlewared/job.py", line 488, in run await self.future File "/usr/lib/python3/dist-packages/middlewared/job.py", line 535, in __run_body rv = await self.middleware.run_in_thread(self.method, *args) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1364, in run_in_thread return await self.run_in_executor(io_thread_pool_executor, method, *args, **kwargs) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1361, in run_in_executor return await loop.run_in_executor(pool, functools.partial(method, *args, **kwargs)) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3.11/concurrent/futures/thread.py", line 58, in run result = self.fn(*self.args, **self.kwargs) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/middlewared/service/crud_service.py", line 268, in nf rv = func(*args, **kwargs) ^^^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/middlewared/schema/processor.py", line 55, in nf res = f(*args, **kwargs) ^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/middlewared/schema/processor.py", line 183, in nf return func(*args, **kwargs) ^^^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/middlewared/plugins/apps/crud.py", line 287, in do_update app = self.update_internal(job, app, data, trigger_compose=app['state'] != 'STOPPED') ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/middlewared/plugins/apps/crud.py", line 317, in update_internal update_app_config(app_name, app['version'], new_values, custom_app=app['custom_app']) File "/usr/lib/python3/dist-packages/middlewared/plugins/apps/ix_apps/lifecycle.py", line 59, in update_app_config render_compose_templates( File "/usr/lib/python3/dist-packages/middlewared/plugins/apps/ix_apps/lifecycle.py", line 50, in render_compose_templates raise CallError(f'Failed to render compose templates: {cp.stderr}') middlewared.service_exception.CallError: [EFAULT] Failed to render compose templates: Traceback (most recent call last): File "/usr/bin/apps_render_app", line 33, in <module> sys.exit(load_entry_point('apps-validation==0.1', 'console_scripts', 'apps_render_app')()) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/catalog_templating/scripts/render_compose.py", line 47, in main render_templates_from_path(args.path, args.values) File "/usr/lib/python3/dist-packages/catalog_templating/scripts/render_compose.py", line 19, in render_templates_from_path rendered_data = render_templates( ^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/catalog_templating/render.py", line 36, in render_templates ).render({'ix_lib': template_libs, 'values': test_values}) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/usr/lib/python3/dist-packages/jinja2/environment.py", line 1301, in render self.environment.handle_exception() File "/usr/lib/python3/dist-packages/jinja2/environment.py", line 936, in handle_exception raise rewrite_traceback_stack(source=source) File "/mnt/.ix-apps/app_configs/jellyfin/versions/1.1.7/templates/docker-compose.yaml", line 3, in top-level template code {% set c1 = tpl.add_container(values.consts.jellyfin_container_name, "image") %} ^^^^^^^^^^^^^^^^^^^^^^^^^ File "/mnt/.ix-apps/app_configs/jellyfin/versions/1.1.7/templates/library/base_v2_0_21/render.py", line 53, in add_container container = Container(self, name, image) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/mnt/.ix-apps/app_configs/jellyfin/versions/1.1.7/templates/library/base_v2_0_21/container.py", line 63, in __init__ self.deploy: Deploy = Deploy(self._render_instance) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/mnt/.ix-apps/app_configs/jellyfin/versions/1.1.7/templates/library/base_v2_0_21/deploy.py", line 15, in __init__ self.resources: Resources = Resources(self._render_instance) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/mnt/.ix-apps/app_configs/jellyfin/versions/1.1.7/templates/library/base_v2_0_21/resources.py", line 24, in __init__ self._auto_add_gpus_from_values() File "/mnt/.ix-apps/app_configs/jellyfin/versions/1.1.7/templates/library/base_v2_0_21/resources.py", line 55, in _auto_add_gpus_from_values raise RenderError(f"Expected [uuid] to be set for GPU in slot [{pci}] in [nvidia_gpu_selection]") base_v2_0_21.error.RenderError: Expected [uuid] to be set for GPU in slot [0000:01:00.0] in [nvidia_gpu_selection]
Any ideas?
He/Him
He/Him
He/Him
