build pc My first PC
6 hours ago, HarmanSS said:I at-least want an 8-core CPU, both of you suggested AM5 builds, so here's one that I made for AM5. Although my max budget is $2000 CAD, I do want to keep as low as possible as such this is also under 1500 CAD. I am not sure about the CPU, coz Ryzen 7700($409) doesn't seem much different than 8700F($340), other than the L3 caches as such it should not have a major impact on performance. For PSU, 650W is more than enough, so do I need to get higher watts for some reason, as both suggestions had a higher wattage PSU.
If it were me, I would have spend the extra 50$, that's like 2.5% increase in total budget. 8700f is actually a cut down version, as it just the APU 8700G without igpu(integrated graphics). That thing is slower than even the 7500f, which is technically a 7600 without igpu) or get 7700xt instead of 7800xt. With your budget, I also wouldn't recommend getting 5000 series, there's really no future upgrade path other than the x3d. At the very least, with 7000/9000, even if you won't upgrade for another 5-7yrs and AM5 is no longer supported by amd. At this time with the current amd "promised', you are still looking at 1-2 generation that would support the platform(10k and 11k, or whatever they will call it). Meaning you will still just need to buy a cpu in the future and still get decent to great performance upgrade.
If you really decide to get that newegg build, I would try to replace the psu to at least a 750w. You can definitely use a 650w on a 7800xt+8700f combination, but if you do, I would suggest to undervolt your gpu, just in case. Also PSU are some of the things you can over spec, as most of the time, you will be caring over that to future upgrades. Some even survive up to 15yrs or more and the only thing that breakdowns first are actually the fans to a well built and taken care of psu.
CPU: AMD Ryzen 7 7700X 4.5 GHz 8-Core Processor ($398.50 @ Vuugo)
CPU Cooler: Thermalright Peerless Assassin 90 SE 32.77 CFM CPU Cooler ($34.54 @ Amazon Canada)
Motherboard: ASRock B650M Pro RS WiFi Micro ATX AM5 Motherboard ($184.99 @ Newegg Canada)
Memory: TEAMGROUP T-Force Vulcan 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory ($109.99 @ Canada Computers)
Storage: Silicon Power UD90 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive ($135.88 @ Amazon Canada)
Video Card: XFX Speedster SWFT 210 Core Radeon RX 7800 XT 16 GB Video Card ($678.97 @ Newegg Canada)
Case: Montech X3 Mesh ATX Mid Tower Case ($67.63 @ Vuugo)
Power Supply: Cooler Master MWE Gold 850 - V2 850 W 80+ Gold Certified Fully Modular ATX Power Supply ($134.50 @ Vuugo)
Monitor: Gigabyte GS32Q 31.5" 2560 x 1440 170 Hz Monitor ($309.99 @ Memory Express)
Total: $2054.99
Generated by PCPartPicker 2024-11-14 21:39 EST-0500
