Gsync only working on left most monitor in display arrangement.
So this is a weird one, I have a middle monitor that I use for games and I thought Gsync just sucked but then checked the refresh on the monitor and saw it wasn't changing, so for fun I went to my display settings and rearranged my displays so my middle monitor was on the left. Gsync worked then, tested it on each of my other two monitors and with the same result, is this normal? Is there a way to fix this?
Dell G15 Ryzen Edition
CPU: Ryzen 5 5600H GPU: RTX 3050 RAM: 32GB DDR4 Storage: 512GB + 4TB SSD
MSI Modern 14
CPU: i7-10510U GPU: Nvidia MX 330 RAM: 16GB DDR4 Storage: 1TB SSD
1 hour ago, Tridefender said:
Did you use dp cables? Free sync over HDMI is pretty much amd only
Yes each display is using a DP cable
MSI Modern 14
