Vertical case recommendations which would fit my build.
25 minutes ago, Trembletop said:All I can think of is the Ncase M2, having a full sized PSU and GPU don't really combine to SFF, the title of SFF is usually given to mini ITX or builds without a dedicated GPU. The Ncase M2 should fit your GPU though, unfortunately SFF and cheap don't really mix too. I think this case is your best option. https://ncased.com/collections/all-products/products/m2-angle
Do they not show specs like dimensions, compatibility, maximum cooler height, PSU size etc? Or am I just missing this? And it being a flatpack (i.e. not riveted), it is less sturdy? For that money, they should document it better.
OP: you are better off referring to ATX standard sizes you require. SFF "usually" are the proprietary systems that have tiny PSU, half-height GPU etc. In your case you need a case for mATX MB, ATX PSU (good to provide the length since that isn't standard), cooler height, and GPU length. Cases provide those numbers. Also assume future upgrade like when a future PSU may be 1cm longer.
I recently came across the Jonsbo D30 or D32Pro, Asus AP201, and the LianLi A3-mATX. I had to exclude many contenders due to PSU or cooler clearance.
If you want even smaller cases, you are looking at ITX MB and SFF PSU (=much more pricy for less performance and thermals). Saving a tiny bit of footprint is pricy. Some of the ITX cases even have larger dimensions than the mATX cases I listed.
