How to install Artic freezer iii AIO
Go to solution Solved by WoodenMarker,
You can plug the all-in-one cable into the CPU_FAN header. This synchronizes the pump, vrm , and fan.
The CPU_OPT header just follows the same settings as the CPU_FAN header.
Plug the argb cable into any of the ARGB_V2_1/2/3 headers.
Hello, I'm not sure if this should go under new builds, AIO, or motherboards.
But i have a x670 gaming x AX v2 and an Artic Liquid Freezer iii 420 AIO, looking at the install vid there is one cable that only says CPU on it and the video says it can be used for everything or i can use a 3 in 1 cable that says pump, vrm, and fan, on the top right of my mobo there is a slot for "cpu fan" and "cpu opt" There is also another cable which from the video is for RGB, im assuming i can put it anywhere that says rgb on the mobo?
I am unsure what to do,
Edited by Nut Loaf
added the rgb cable info
https://linustechtips.com/topic/1588430-how-to-install-artic-freezer-iii-aio/
