Asus laptop Battery sometimes instantly discharges to 0% as soon as it is turned on without charger
The battery in my Laptop sometimes instantly discharges to 0 and shuts off as soon as I power on the device without the charger. If I power on with the charger then it stays near to the last known charge percentage. This dropping to 0 started happening in early 2023 as far as I remember. Laptop was bought in October 2020.
Is the battery a goner or is there something else at play here? There is no swelling in the battery though.
I suspect that one cell maybe weak or dying in the laptop and when it runs on battery power the laptop drains the whole cell because there is less voltage because of that faulty cell.
Here is my battery report:
Edited by Tech Reprise
Image added for battery report
  • AMD Ryzen 7 5700X Undervolted  with PBO+Eco Mode
  • B550 Aorus Elite V2 Rev1.2
  • G.Skill TridentZ RGB 3600Mhz 32gb (8gb x4)
  • MSI Mech 2X RX6600 8GB GDDR6
  • Deepcool AK620 WH
  • Deepcool CK500 WH
  • WD SN770 500gb + WD Blue 1tb HDD, Sn550 1tb + MX500 1000gb
  • Antec EAG Pro 750 80+G
  • Benq Mobiuz EX2510 144Hz
Might help to list the model number, how you use the laptop, etc.
Also if you can post an image instead, probably more helpful. Most people don't like downloading random files.
Storage: WD 750 SE 500GB, WD 730 SE 1TB GPU: EVGA RTX 3070 Ti PSU: Corsair SF750 Case: Streacom DA2
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
1 hour ago, Kisai said:
Almost certainly. And Asus won't be any help getting a replacement.
Yes, Asus is charging nearly $150 for a replacement that too on pre-order basis.
OEM is $50-$70
  • Deepcool AK620 WH
  • Deepcool CK500 WH
Edited the post.
Laptop model is Asus TUF FX505DT, primary use is for making presentations. Since this 0% issue occurs I keep it connected all times. I tried bios reflashing but it didn't help.
  • Deepcool AK620 WH
  • Deepcool CK500 WH
Batteries are wear items. After 4 years, replace.
Try not to run on battery all the time unless you have to. I don't know your use, but I often see people using laptops on battery even if they are on a desk or somewhere where there is power. A battery only has so many charge cycles it is built for. Add heat etc.
They aren't made and pampered to last long. In an EV, there is ton of cooling, heating and smart technology to make them last 10-15 years. But not in a laptop. Laptops are disposable items.
No signature
I do the opposite. I turn on Asus 80% charge limit and use on AC power 90% of the time.
10 hours ago, Tridefender said:
Buy a replacement battery on Amazon/eBay, I did a small search and lots of options popped up
Ebay is not available as a marketplace and Amazon doesn't have any battery with good reviews here.
  • Deepcool AK620 WH
  • Deepcool CK500 WH
I'd recommend buying an original battery or a known brand with UL listing or whatever batteries require.
Faulty batteries can cause ugly fires. Don't cheap out on battery.
No signature
Bruh just search "your laptop model" replacement battery
Amazon and eBay are just results based on my IP, you don't have to do the exactly same thing
Bruh, read the "full post before commenting" ↓↓↓. I already have options to get a battery, just buying from random options that pop up on random websites is just as idiotic as buying a 2tb thumb drive for 2$ from Temu is.
OEM is $50-$70
  • Deepcool AK620 WH
  • Deepcool CK500 WH
Thanks for the heads up. Already got quotation of Asus vs OEM sourced batteries. Let's see which one is better and if they cost too much I might just sell the laptop for a new one.
  • Deepcool AK620 WH
  • Deepcool CK500 WH
Good call. Evaluate the entire device before sinking money in. If it also lacks power or options you want, it is better to sell the old one. Or use it for a function not requiring battery.
I had used an old laptop for my living room TV for some years. Battery was dead, and power was just enough to watch Netflix. So that was a good way to recycle.
Sadly with lack of cooling, soldered everything and bad batteries, laptops are throwaway devices
No signature
