Recent issues with bsod and random crashing (minidump analyze posted)
Hello, the past month I've been having issues on and off with my system either crashing with a bsod or just everything going black and restarting under load,  I've never seen this happen when just browsing the net, it's always when gaming.  The crashes goes away once i disable CPB which makes me think one of the cores might be screwed and i just need to rma the CPU, would like a confirmation if possible
************* Preparing the environment for Debugger Extensions Gallery repositories **************
   ExtensionRepository : Implicit
   UseExperimentalFeatureForNugetShare : true
   AllowNugetExeUpdate : true
   NonInteractiveNuget : true
   AllowNugetMSCredentialProviderInstall : true
   AllowParallelInitializationOfLocalRepositories : true
   EnableRedirectToChakraJsProvider : false
   -- Configuring repositories
      ----> Repository : LocalInstalled, Enabled: true
      ----> Repository : UserExtensions, Enabled: true
>>>>>>>>>>>>> Preparing the environment for Debugger Extensions Gallery repositories completed, duration 0.000 seconds
************* Waiting for Debugger Extensions Gallery to Initialize **************
>>>>>>>>>>>>> Waiting for Debugger Extensions Gallery to Initialize completed, duration 0.032 seconds
   ----> Repository : UserExtensions, Enabled: true, Packages count: 0
   ----> Repository : LocalInstalled, Enabled: true, Packages count: 42
Microsoft (R) Windows Debugger Version 10.0.27725.1000 AMD64
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\Windows\Minidump\110524-6406-01.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
************* Path validation summary **************
Response                         Time (ms)     Location
Deferred                                       srv*
Symbol search path is: srv*
Executable search path is:
Windows 10 Kernel Version 19041 MP (16 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS Personal
Edition build lab: 19041.1.amd64fre.vb_release.191206-1406
Kernel base = 0xfffff803`3ca00000 PsLoadedModuleList = 0xfffff803`3d62a7c0
Debug session time: Tue Nov  5 17:34:18.047 2024 (UTC + 2:00)
System Uptime: 0 days 1:06:01.669
Loading Kernel Symbols
Loading User Symbols
PEB is paged out (Peb.Ldr = 00000071`56ed5018).  Type ".hh dbgerr001" for details
Loading unloaded module list
For analysis of this file, run !analyze -v
nt!KeBugCheckEx:
fffff803`3cdfe310 48894c2408      mov     qword ptr [rsp+8],rcx ss:ffffe700`f7cee950=0000000000000124
12: kd> !analyze -v
*                        Bugcheck Analysis                                    *
WHEA_UNCORRECTABLE_ERROR (124)
A fatal hardware error has occurred. Parameter 1 identifies the type of error
source that reported the error. Parameter 2 holds the address of the
nt!_WHEA_ERROR_RECORD structure that describes the error condition. Try !errrec Address of the nt!_WHEA_ERROR_RECORD structure to get more details.
Arguments:
Arg1: 0000000000000000, Machine Check Exception
Arg2: ffff85014882b028, Address of the nt!_WHEA_ERROR_RECORD structure.
Arg3: 00000000fc800800, High order 32-bits of the MCi_STATUS value.
Arg4: 00000000060c0859, Low order 32-bits of the MCi_STATUS value.
Debugging Details:
***    Either you specified an unqualified symbol, or your debugger   ***
***    doesn't have full symbol information.  Unqualified symbol      ***
***    resolution is turned off by default. Please either specify a   ***
***    fully qualified symbol module!symbolname, or enable resolution ***
***    of unqualified symbols by typing ".symopt- 100". Note that     ***
***    enabling unqualified symbol resolution with network symbol     ***
***    server shares in the symbol path may cause the debugger to     ***
***    appear to hang for long periods of time when an incorrect      ***
***    symbol name is typed or the network symbol server is down.     ***
***    For some commands to work properly, your symbol path           ***
***    must point to .pdb files that have full type information.      ***
***    Certain .pdb files (such as the public OS symbols) do not      ***
***    contain the required information.  Contact the group that      ***
***    provided you with these symbols if you need this command to    ***
***    work.                                                          ***
***    Type referenced: hal!_WHEA_PROCESSOR_GENERIC_ERROR_SECTION                ***
***    work.                                                          ***
KEY_VALUES_STRING: 1
    Key  : Analysis.CPU.mSec
    Value: 2359
    Key  : Analysis.Elapsed.mSec
    Value: 7844
    Key  : Analysis.IO.Other.Mb
    Value: 1
    Key  : Analysis.IO.Read.Mb
    Value: 1
    Key  : Analysis.IO.Write.Mb
    Value: 4
    Key  : Analysis.Init.CPU.mSec
    Value: 437
    Key  : Analysis.Init.Elapsed.mSec
    Value: 3199
    Key  : Analysis.Memory.CommitPeak.Mb
    Value: 95
    Key  : Analysis.Version.DbgEng
    Value: 10.0.27725.1000
    Key  : Analysis.Version.Description
    Value: 10.2408.27.01 amd64fre
    Key  : Analysis.Version.Ext
    Value: 1.2408.27.1
    Key  : Bugcheck.Code.LegacyAPI
    Value: 0x124
    Key  : Bugcheck.Code.TargetModel
    Value: 0x124
    Key  : Failure.Bucket
    Value: 0x124_0_AuthenticAMD_PROCESSOR__UNKNOWN_IMAGE_AuthenticAMD.sys
    Key  : Failure.Hash
    Value: {035dcc87-485b-74b3-1c1b-ee50cb0c2865}
    Key  : WER.OS.Branch
    Value: vb_release
    Key  : WER.OS.Version
    Value: 10.0.19041.1
BUGCHECK_CODE:  124
BUGCHECK_P1: 0
BUGCHECK_P2: ffff85014882b028
BUGCHECK_P3: fc800800
BUGCHECK_P4: 60c0859
FILE_IN_CAB:  110524-6406-01.dmp
FAULTING_THREAD:  ffff8501581b2080
BLACKBOXBSD: 1 (!blackboxbsd)
BLACKBOXNTFS: 1 (!blackboxntfs)
BLACKBOXWINLOGON: 1
CUSTOMER_CRASH_COUNT:  1
PROCESS_NAME:  TL.exe
STACK_TEXT:
ffffe700`f7cee948 fffff803`3ceba21a     : 00000000`00000124 00000000`00000000 ffff8501`4882b028 00000000`fc800800 : nt!KeBugCheckEx
ffffe700`f7cee950 fffff803`38d115b0     : 00000000`00000000 ffff8501`4882b028 ffff8501`473f3cb0 ffff8501`4882b028 : nt!HalBugCheckSystem+0xca
ffffe700`f7cee990 fffff803`3cfbc82d     : 00000000`00000000 ffffe700`f7ceea29 ffff8501`4882b028 ffff8501`473f3cb0 : PSHED!PshedBugCheckSystem+0x10
ffffe700`f7cee9c0 fffff803`3cebbb41     : ffff8501`4d47a900 ffff8501`4d47a900 ffff8501`473f3d00 ffff8501`473f3cb0 : nt!WheaReportHwError+0x3dd
ffffe700`f7ceea90 fffff803`3cebbeb3     : 00000000`0000000c ffff8501`473f3d00 ffff8501`473f3cb0 00000000`0000000c : nt!HalpMcaReportError+0xb1
ffffe700`f7ceec00 fffff803`3cebbd90     : ffff8501`45cfe8a0 00000000`00000000 ffffe700`f7ceee00 00000000`00000000 : nt!HalpMceHandlerCore+0xef
ffffe700`f7ceec50 fffff803`3cebb2d5     : ffff8501`45cfe8a0 ffffe700`f7ceeef0 00000000`00000000 00000000`00000000 : nt!HalpMceHandler+0xe0
ffffe700`f7ceec90 fffff803`3cebda95     : ffff8501`45cfe8a0 00000000`00000000 00000000`00000000 00000000`00000000 : nt!HalpHandleMachineCheck+0xe9
ffffe700`f7ceecc0 fffff803`3cf13919     : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!HalHandleMcheck+0x35
ffffe700`f7ceecf0 fffff803`3ce0f57a     : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiHandleMcheck+0x9
ffffe700`f7ceed20 fffff803`3ce0f237     : 00000000`00000000 00000000`00000000 00000071`41b5f890 00000000`00000000 : nt!KxMcheckAbort+0x7a
ffffe700`f7ceee60 00007ffb`5bf490aa     : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiMcheckAbort+0x277
00000071`41b5f818 00000000`00000000     : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x00007ffb`5bf490aa
MODULE_NAME: AuthenticAMD
IMAGE_NAME:  AuthenticAMD.sys
STACK_COMMAND:  .process /r /p 0xffff85015d047340; .thread 0xffff8501581b2080 ; kb
FAILURE_BUCKET_ID:  0x124_0_AuthenticAMD_PROCESSOR__UNKNOWN_IMAGE_AuthenticAMD.sys
OS_VERSION:  10.0.19041.1
BUILDLAB_STR:  vb_release
OSPLATFORM_TYPE:  x64
OSNAME: Windows 10
Loading Dump File [C:\Windows\Minidump\110524-10125-01.dmp]
Deferred                                       srv*
Kernel base = 0xfffff800`56c00000 PsLoadedModuleList = 0xfffff800`5782a7c0
Debug session time: Tue Nov  5 22:59:28.601 2024 (UTC + 2:00)
System Uptime: 0 days 0:21:58.186
PEB is paged out (Peb.Ldr = 00000024`a8961018).  Type ".hh dbgerr001" for details
nt!KeBugCheckEx:
fffff800`56ffe310 48894c2408      mov     qword ptr [rsp+8],rcx ss:ffff8380`87e9b950=0000000000000124
6: kd> !analyze -v
Arguments:
Arg2: ffffe0850d82b028, Address of the nt!_WHEA_ERROR_RECORD structure.
Arg3: 00000000bc000800, High order 32-bits of the MCi_STATUS value.
Arg4: 0000000001010135, Low order 32-bits of the MCi_STATUS value.
Debugging Details:
***    work.                                                          ***
***    work.                                                          ***
    Value: 2140
    Value: 3093
    Value: 0
    Value: 1
    Value: 0
    Value: 421
    Value: 2629
    Value: 94
    Value: 1.2408.27.1
    Value: 0x124
    Value: 0x124
    Key  : Failure.Hash
    Key  : WER.OS.Branch
    Value: vb_release
    Value: 10.0.19041.1
BUGCHECK_CODE:  124
BUGCHECK_P1: 0
BUGCHECK_P2: ffffe0850d82b028
BUGCHECK_P3: bc000800
BUGCHECK_P4: 1010135
FILE_IN_CAB:  110524-10125-01.dmp
FAULTING_THREAD:  ffffe0851ea4d080
BLACKBOXWINLOGON: 1
PROCESS_NAME:  cs2.exe
STACK_TEXT:
ffff8380`87e9b948 fffff800`570ba21a     : 00000000`00000124 00000000`00000000 ffffe085`0d82b028 00000000`bc000800 : nt!KeBugCheckEx
ffff8380`87e9b950 fffff800`53c815b0     : 00000000`00000000 ffffe085`0d82b028 ffffe085`0afebd60 ffffe085`0d82b028 : nt!HalBugCheckSystem+0xca
ffff8380`87e9b990 fffff800`571bc82d     : 00000000`00000000 ffff8380`87e9ba29 ffffe085`0d82b028 ffffe085`0afebd60 : PSHED!PshedBugCheckSystem+0x10
ffff8380`87e9b9c0 fffff800`570bbb41     : ffffe085`0ae68ac0 ffffe085`0ae68ac0 ffffe085`0afebdb0 ffffe085`0afebd60 : nt!WheaReportHwError+0x3dd
ffff8380`87e9ba90 fffff800`570bbeb3     : 00000000`00000006 ffffe085`0afebdb0 ffffe085`0afebd60 00000000`00000006 : nt!HalpMcaReportError+0xb1
ffff8380`87e9bc00 fffff800`570bbd90     : ffffe085`0acfe450 8b48d68b`00000000 ffff8380`87e9be00 880fc085`44244489 : nt!HalpMceHandlerCore+0xef
ffff8380`87e9bc50 fffff800`570bb2d5     : ffffe085`0acfe450 ffff8380`87e9bef0 00000000`00000000 7402a850`478b003b : nt!HalpMceHandler+0xe0
ffff8380`87e9bc90 fffff800`570bda95     : ffffe085`0acfe450 ffc4ba50`e8cf8b48 ffc4b588`e8cf8b48 f60b8b68`24448948 : nt!HalpHandleMachineCheck+0xe9
ffff8380`87e9bcc0 fffff800`57113919     : 8b480d75`c0854850 8ce9ffc5`b482e8cf 8d41c033`45000001 242ee8c8`8b480150 : nt!HalHandleMcheck+0x35
ffff8380`87e9bcf0 fffff800`5700f57a     : 0fc03345`000000b8 4de8c88b`484c50b6 8948d88b`48ffc4b6 2475c085`48782444 : nt!KiHandleMcheck+0x9
ffff8380`87e9bd20 fffff800`5700f237     : 00000000`00000000 00000000`00000000 0000016a`2ac4e130 00000000`00000000 : nt!KxMcheckAbort+0x7a
ffff8380`87e9be60 00007ff8`5e76a418     : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiMcheckAbort+0x277
00000024`a9f7b280 00000000`00000000     : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x00007ff8`5e76a418
STACK_COMMAND:  .process /r /p 0xffffe0851e14e340; .thread 0xffffe0851ea4d080 ; kb
OSNAME:  Windows 10
FAILURE_ID_HASH:  {035dcc87-485b-74b3-1c1b-ee50cb0c2865}
Followup:
MachineOwner
PC Specs
Ryen 5800x
RTX 3070
GSkill DDR4 3000mhz
Corsair rm850
b450 gaming x
