Hey everyone,
Back in 2022 I bought an MSI Optix MAG274QRFDE-QD, which worked flawlessly until 3 weeks ago, where I started noticing some random flickering. After sending it back to MSI for a warranty repair they told me that the monitor was indeed faulty but that it wasn't repairable, so they told me they'd like to offer an MSI G274QPX as a replacement.
I asked them if refunding was an option, but they said no. However they were open to negotiate the replacement. From their standpoint the MSI G274QPX is of the same value as the one I had, but I'm not familiar with this monitor.
I use the monitor mainly for gaming and office work.
Any advice on what I should do? Is the MSI G274QPX a good replacement?
Thanks in advance!
https://linustechtips.com/topic/1587788-msi-replacement-monitor-advice/
Its an upgrade.
Ryzen 7 7800x3D -  Asus RTX4090 TUF OC- Asrock X670E Taichi - 32GB DDR5-6000CL30 - SuperFlower 1000W - Fractal Torrent - Assassin IV - 42" LG C2
Ryzen 7 5800x - XFX RX6600 - Asus STRIX B550i - 32GB DDR4-3200CL14 - Corsair SF750 - Lian Li O11 Mini - EK 360 AIO - Asus PG348Q
Yea, I would take the deal.
  • 27" IPS panel (2560 x 1440 QHD)
  • 240Hz refresh rate - Display without after image.
  • 1ms response time helps eliminate screen tearing and choppy frame rates
  • Wide view angle - 178° visible.
  • Adaptive sync - keep screen tearing away from your monitor.
In case you're not aware, it wont have "1ms" response times, that's just what they put on the box. Only the highest end LCD's get anywhere close. Also this is referencing pixel response time so it won't have an effect on screen tearing or framerates.
Ultimately unrelated but hey, the more you know.
5 hours ago, Adagio24 said:
it's worth about 100usd more than the monitor that was sent in.
5950x 1.33v 5.05 4.5 88C 195w ll R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-24-2T (zen trfc)  1.45v 45C 1.15v soc ll 6950xt gaming x trio 325w 60C ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll 6x nf12/14 ippc fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll AW3423DW
9900k 1.36v 5.1avx 4.9ring 85C 195w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5500 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-30-280-20 ddr3666bdie 1.45v 45C 1.22sa/1.18 io  ll EVGA 30 non90 tie ftw3 1920//10000 0.85v 300w 71C ll  6x nf14 ippc 2000rpm ll 500gb nvme 970 evo ll l sandisk 4tb sata ssd +4tb exssd backup ll 2x 500gb samsung 970 evo raid 0 llCorsair graphite 780T ll EVGA P2 1200w ll w10p ll NEC PA241w ll pa32ucg-k
prebuilt 5800 stock ll 2x8gb ddr4 cl17 3466 ll oem 3080 0.85v 1890//10000 290w 74C ll 27gl850b ll pa272w ll w11
Hey everyone, thank you for the advice. I just reached out to MSI and they have another model I can choose: MPG 275CQRXF
Thoughts about swapping the MSI Optix MAG274QRFDE-QD for either of these:
  • MSI G274QPX
  • MSI MPG 275CQRXF
Which one is better for gaming and office work?
