I just upgraded my cpu from ryzen 3 3100 to ryzen 7 5700x3d but the clock speed is stuck
Go to solution Solved by YoungBlade,
To confirm, did you update your BIOS to the latest version?
Unfortunately, in order to get a BIOS new enough that it would definitely have support for the 5700X3D specifically means that you'll need to use one of the BIOS that's designated as a "beta" BIOS - unless I'm missing something on the support page:
https://www.asrock.com/mb/AMD/B450M Pro4/index.asp#BIOS
In theory, the 5700X3D does work as long as you at least have AGESA 1.2.0.6b/c - which appears to be available from BIOS 5.70 - so if you don't want to go with a BIOS marked "beta" then at least make sure you're on that one.
According to the CPU Support page, you need at least version 8.01: https://www.asrock.com/mb/AMD/B450M Pro4/index.asp#CPU
And when you say you used AMD Adrenalin, do you mean that it confirmed your chipset drivers were up to date?
That drastic of a change I would have reset the CMOS and/or taken the opportunity to update the BIOS. Also uninstalled old chipset drivers and installed the latest fresh.
Ryzen 7 7800x3D -  Asus RTX4090 TUF OC- Asrock X670E Taichi - 32GB DDR5-6000CL30 - SuperFlower 1000W - Fractal Torrent - Assassin IV - 42" LG C2
Ryzen 7 5800x - XFX RX6600 - Asus STRIX B550i - 32GB DDR4-3200CL14 - Corsair SF750 - Lian Li O11 Mini - EK 360 AIO - Asus PG348Q
Also check if power settings haven't reset to something like laptop/savings mode but is on no limits power mode. That happened when I upgraded.
Desktop: Ryzen 7 5800X3D - Kraken X62 Rev 2 - STRIX X470-I - 3600MHz 32GB Kingston Fury - 250GB 970 Evo boot - 2x 500GB 860 Evo - 1TB P3 - 4TB HDD - RX6800 - RMx 750 W 80+ Gold - Manta - Silent Wings Pro 4's enjoyer
SetupZowie XL2740 27.0" 240hz - Roccat Burt Pro OG Corsair K70 browns - PC38X - Mackie CR5X's
Current build on PCPartPicker
