Weird crackling noise from PC when turn off
Go to solution Solved by Mark Kaine,
9 hours ago, Irafli said:
My pc is start to create weird crackling when turning off after 10 seconds, after I press the switch off button on PSU the noise is gone am I having bad PSU or it because I don't have grounding in my house? (yes my house doesn't have grounding I know this because when I touch  the end of a cable/plug that plug in it shock me)
this is a bad PSU, get a new one asap, best not the same model again, get a Corsair RMX for example.
SPEC:
Windows 11 Latest update
I5 13400f
MSI PRO B760M-A DDR4 wifi - never updated the bios
Team Delta RGB T-Force 32GB 3600Mhz DDR4
PSU Cooler Master V750 Gold V2
Edited by Irafli
Correction
https://linustechtips.com/topic/1585618-weird-crackling-noise-from-pc-when-turn-off/
It could be the fan blades sag at lower spinning velocity and are brushing stuff below it, that's what it sounds like to me. Depending on how long you've had it that should be covered under warranty. A pretty common issue with that PSU in specific and the Coolermaster MWE series is coil whine. It's not dangerous but I don't think it's that because the noise is too deep and spaced out, also you said it happens 10 seconds after shutdown whereas coil whine happens under load. If it is the fan that frictions will shorten the life of your PSU, id recommend just get another one since they're not expensive.
YT video of coil whine
New 750w PSU
-Scott Manley, 2021
Softwares used:
Corsair Link (Anime Edition)
MSI Afterburner
OpenRGB
Lively Wallpaper
OBS Studio
Shutter Encoder
Avidemux
FSResizer
Audacity
VLC
WMP
GIMP
HWiNFO64
Paint
3D Paint
GitHub Desktop
Superposition
Prime95
Aida64
GPUZ
CPUZ
Generic Logviewer
Well I thought this PSU supposed to be good one I looked it up on PSU tier list I only bought it a year ago
Edited by Irafli
Correction
