Dragon Ball Sparking Zero extremley low volume
BaidDSB
I tried everything. But only in game theres an issue. every other game and program is working properly with sound.
Given that the game is still technically prerelease, I'd probably just wait
If you're impatient, contact their customer service and file a bug report.
In the meantime, you could crank your volume to 100, then use volume mixer to reduce every program that isn't the game, though that can (and will) lead to a jumpscare or three as you find programs that weren't running when you dropped the other volumes
how does this help?
That would maximize the volume you can get
