help pointing radarr to nas on ubuntu
L00bs4n00bs
I don't know if anyone who sees this can help me. Ive built a server of sorts running proxmox with open media vault doing my nas and a VM with ubuntu To carry my Plex server, prolarr, radarr and sonarr.
My problem is with setting up radarr when I go to set the root folder it only gives me the ability to add files on the ubunto root folder and not network folders. I have been messing about in the terminal but I don't really know what I'm doing I have tried to follow every online guide I can but again I don't know Linux and I'm finding it difficult to learn as I have no real point of reference.
CPU 7800x3d Motherboard Gigabyte B650 Gaming X AX RAM 64gb 2 sets Corsair Vengeance RGB Black 2x16gb 6000MHz DDR5 GPU RTX 3090 FE
set mount point for network folder via /etc/fstab to the place you have access for radarr setup 🤔
for example, i set up mounting point to /mycloud for my nextcloud server for easy setup
PC Specs - AMD Ryzen 7 3700X - Asrock AB350 ITX - 64GB DDR4-3600MHz - Geforce GTX 1080 - Samsung 960Pro - Monsterlabo's "The First" - Corsair SF450
