So i'm starting to plan a future upgrade (3900X doesn't have the gaming legs i was hoping for/5800X3D doesn't have the sheer number crunching ability i need, fingers crossed the 9800X3D delivers the goods 😛).
and spotting what GPU powerdraw has started to do since i got my RTX 2070S (go from up to crazy), i decided to look at beefing up my custom watercooling/switching to a similar but better airflow case as well (O11-D > 011-D Evo RGB).
now i noticed my possible future case is big enough to support X-Flow radiators of which my current plan is one at the top one at the bottom other bits in between to essentially have the radiators function as tubes to move the liquid around for a really clean look/being stupidly easy to drain by slapping a small drain below the bottom rad.
now my main concern is that the top rad will do next to nothing as my loop is optimized for silence (pump running at ~2500rpm 1.2L/min flowrate) and the top radiator would be behind the gpu/cpu block which are the main restrictions in the loop as after the rad the water just dumps in to the reservoir so there's no restriction/backpressure to help the water "climb the radiator" rather then flee to the exit.
so does anybody have any experience with a X-flow rad in the top of the case and is this actually a issue or is it functionally the same as a normal rad .
my thinking is since a normal rad you only use half the channels, force the water to make a U turn and then go through the other half creates more resistence forcing the water higher in to the rad then a X-flow rad where the full rad is used at once and it might just run strait to the other side and bail only using a few mm of the rad (in height) unless i tell the pump to go full speed ahead which would probably create enough flow to force more use out of the radiator at the cost of pump noise.
I have an EK X-Flow in the top of my o11 EVO XL and it works pretty much as expected.
The only surprise I had was the X-Flow path is not as versatile as I thought. Thankfully, my setup has a left rear port as input and a right front as output.
Somehow I thought ANY port on a single side (front or back) could be input as long as any port on the right was output.
Worked out in the end though.
Not sure if I can quantify performance as its doubled with S240 and is on the GPU loop with the CPU on a separate loop with an X360
Living Room PC - Lian-Li O11 XL Evo - MSI X870 Tomahawk Mobo - AMD 9800X3D - 32GB DDR5 Ram - RTX 4090 - 2TB Samsung 990Pro NVMe - Antec 1200w PSU - Dual Custom Loop Cooling - GPU cooled with EK Quantum Surface S240 + EK Quantum Surface P360M X-Flow Rads - CPU cooled with EK Quantum Surface X360M Rad
Bedroom PC - Hyte Y60 - Intel Core i5 13600k - MSI Pro-A Wifi Z790 Mobo DDR5 - 32GB Ram - RTX 3080ti - 1TB Samsung 990Pro NVMe - Corsair HX1200i PSU - CPU + GPU cooled with Hyte Y60 Corner Distro Plate - EK Coolstream S120 + EK Quantum Surface S360 + EK Quantum Surface X240M
Extension PC - Lian Li o11 Dynamic - Intel Core i9 9900k - MSI Meg Ace Z390 Mobo - 16GB Ram - RTX 2080ti - 256GB Samsung NVMe - Corsair AX850 PSU - CPU + GPU cooled with dual EKWB 360 Rads + G1 side EKWB distro plate.
Kitchen PC - Thermaltake Tower 100 - Intel Core i7 8086K - Gbyte Z390 I Aorus Pro Wifi Mobo - 16GB Ram - iGPU - 256GB Samsung NVMe - EVGA B5 850W PSU - CPU cooled with dual EK Quantum Surface P120M Rads + Barrow 3-in-1 Block, Res & Pump.
Annex - Corsair 250D - Intel Core i7 8700k - Gbyte Z390 I Aorus Pro Wifi Mobo - 16GB Ram - GTX 1080ti - 256GB Samsung NVMe - BeQuiet P11 750 PSU - CPU cooled with EK Coolstream S240 + S120 Rads + EK Pump / Res Combo
Office - Corsair 280X - Intel Core i7 4790k - Asrock H97M ITX Mobo  - 16GB Ram - EVGA GTX 980 - Corsair SFXL600 PSU - CPU + GPU cooled with triple EK Coolstream S240s + EK Pump / Res Combo
NAS PC - Fractal Node 804 - Intel Core i7 3770k - Asus P8Z77-M Mobo - 16GB Ram - MSI GTX 1660 Ventus - Corsair AX850 PSU - Unraid 21TB Storage Server
Living Room AV Setup 5.1.4 - Nvidia Shield - Yamaha RX-A6A - 2 x B&W CM9s2 - 2 x Monitor Audio FX Silvers - 4 x B&W CCM665s - B&W CMCs2 - SVS SB13 Ultra - LG OLED65C1
Extension AV Setup - Sonos ARC + Sub (Gen 3) - LG OLED65C6V + Sonos Amp - 5 x Monitor Audio C265s
Bedroom AV Setup - Yamaha WXC-50 - 2 x B&W CM1s - Rel Quake - LG OLED42C2.
I've used Alphacool X-flow radiators (both top and bottom in my old Phanteks 719 and currently my 2 x Lian Li O11D XL cases) for years at this point. Both of my O11D XL's run a top 30mm 360 X-flow, a bottom 45mm 360 X-flow along with a side 30mm 360 U-flow. No issues with them what-so-ever as long as you can account for the slight increase in their size over a traditional U-type radiator. And as @NorKris states, they present less resistance than a traditional flow radiator.
ah that's good to know, thank you very much 🙂
i was thinking it's probably not a real issue though as @Blai5e is doing would probably go for the thicker one at the bottom and the thinner one up top.
the O11 Evo RGB can take a 420 rad (with extra bracket) up top so a 360 X rad should fit and the bottom only officially supports a 360 but it should fit as the case is ~6cm longer then the rad -1cm for the pci-e area and i should have enough space to cram a spring release drain on the side for my super simple draining solution.
was thinking of getting a rad in the side but think that will just be intake/pumpres combo mounting to keep the loop super simple and ez to 99% drain for maintenance all the solution i can think of invole mounting the res at only 1 point which....i do not like (acrylic pump top would be the only mounting point) can already hear the acrylic crack wile i'm doing combat with a tube 😛.
i mean the 011D didn't want me to mount my side rad the way i did but a metal file later it went in there how i wanted 😛 and it didn't want me to place a 120mm fan next to my top 240 rad but again a metal file later 3 screws are keeping that fan level 😛 so i'm sure it'll work out as long as it physically fits inside of the case ^^
  • 1 month later...
x flow is just less restriction but since the gpu and cpu have jet plats flow speed wont matter.
the flow wont matter ether as its closed loop once the air is out it wont flow faster downward do to suction.
back then before the jetplate flow was king and the more you had the lower the temp so people would make the smallest loop posable less 90 degrees and over volt there pump. the x flow rad was just before the time the jetplate came out on the xspc ray strom cpu block witch restricks the flow but also got same cooling or better. problems of so much flow was fittings popping off, blocks cracking, faster etching, and lower pump hours.
now the xflow is for looks, fitting placement or side mount.
Edited by thrasher_565
Corsair Lian Li Bykski Barrow thermaltake nzxt aquacomputer 5v argb pin out guide + argb info
5v device to 12v mb header
Odds and Sods Argb Rgb Links
