I am building a NAS and would want to install 3 drives (2 data, 1 redundant). Is it possible to buy 3 external 3.5 inch harddrives (ex. Seagate One Touch Hub or WD My Book), extract the drive and use them in a NAS without issue? I compared the price for them in my country and higher capacity ones are usually over 100 USD (equivalent) cheaper than an same size internal 3.5 inch HDD. Thanks.
Something interesting I found out recently... apparently they don't make SMR drives above 10TB.
I can't remember where I saw this info, I was looking into buying some 16/18TB drives and wanted to make sure they weren't SMR. So at least that's a relief if you don't have to try a deep dive on those drives at least.
Please quote my post, or put @paddy-stone if you want me to respond to you.
  • PCs:-
  • Main PC build  https://uk.pcpartpicker.com/list/2K6Q7X
  • ASUS x53e  - i7 2670QM / Sony BD writer x8 / Win 10, Elemetary OS, Ubuntu/ Samsung 830 SSD
  • Lenovo G50 - 8Gb RAM - Samsung 860 Evo 250GB SSD - DVD writer
  • Displays:-
  • Philips 55 OLED 754 model
  • Panasonic 55" 4k TV
  • LG 29" Ultrawide
  • Philips 24" 1080p monitor as backup
  • Storage/NAS/Servers:-
  • ESXI/test build  https://uk.pcpartpicker.com/list/4wyR9G
  • Main Server https://uk.pcpartpicker.com/list/3Qftyk
  • Backup server - HP Proliant Gen 8 4 bay NAS running FreeNAS ZFS striped 3x3TiB WD reds
  • HP ProLiant G6 Server SE316M1 Twin Hex Core Intel Xeon E5645 2.40GHz 48GB RAM
  • Gaming/Tablets etc:-
  • Xbox One S 500GB + 2TB HDD
  • PS4
  • Nvidia Shield TV
  • Xiaomi/Pocafone F2 pro 8GB/256GB
  • Xiaomi Redmi Note 4
  • Unused Hardware currently :-
  • 4670K MSI mobo 16GB ram
  • i7 6700K  b250 mobo
  • Zotac GTX 1060 6GB Amp! edition
  • Zotac GTX 1050 mini
My home server uses shucked 12 TB WD MyBook drives. Depending on the backplane you might have to tape over a power pin so they don't misinterpret a power feed as a "shut off" command, but in the chassis I've used they've just worked.
