How much performance do I get by upgrading my RAM from 16GB 3200MHz to 32GB 3600MHz?
On 10/6/2024 at 9:01 PM, Caveman0407 said:I'm thinking about upgrading my laptop
Specs: (Asus ROG Strix G15 2021)
- R7 5800h
- RTX 3050TI
Probably zero to inconsequential in terms of gaming, the increase speed from 3200mhz to 3600mhz would be the main reason for this, if there are any gain. But as for increasing from 16gb to 32gb, the main thing it would improve on is your multitasking. If you are opening multiple tabs on your browser or running a lot of apps at the same time. Some professional task also benefits by adding more rams, like video editing, 3d model and render, etc. But normal day to day usage, probably 16gb is just enough and 32gb if the resolution is 1440p or higher, or you like to use multiple monitors and more than one applications are open at the same time. In todays time and pricing, 32gb seems a good choice.
