Screenshot2024-10-04at19_58_26.thumb.png.e5f4445a3e776c4b07e3487f84bfb549.pngBudget : 1000 €
Games, programs or workloads that it will be used for: Forza Horizon 5 , Microsft Flight Simulator 2020
Other details : Idealy i would like to play at 1440p at 60fps, would like it to be white and tell me if you thinis pc part picker list is good
Definitely get a 2x8GB RAM kit, you give up a significant amount of performance with just 1 RAM stick.
English is not my first language, so please excuse any confusion or misunderstandings on my end, also I like to edit my posts a lot.
F@H-Stats (expand for machine specs)
The Folding rigs:
Rig 1:
CPU: 2x Xeon E5 2690 V3
Rig 2:
CPU: Ryzen 5 5600
GPU: GTX 1080
Rig 3:
CPU: Core i7 4790K
GPU: GTX 1060 3GB
The Laptop (Lenovo Legion 5 15IAH7):
CPU: Core i5 12500H
RAM: 16GB (2x8GB) DDR5-4800
GPU: RTX 3050 Ti mobile
OS: Windows 11 Home
The Tablet:
Dell Latitude 7212 Rugged Extreme Tablet (Core i5 8350U/8GB RAM)
OS: Windows 11 Pro
Ryzen 7600 costs 180 eur (with good enough cooler)
Asrock b650m pg lightning 120 eur.
You get upgradeablity and better performance.
I would drop wireless keyboard and upgrade to 32gb kit of 6000mhz cl30 ram
Budget : 1000 €
And where you from? Different countries can have significantly different prices.
current PC:
PC configs I used before:
3 hours ago, SquishyMr said:
Slovakia
19 hours ago, SquishyMr said:
Budget : 1000 €
White build or case? Because most of the parts are quite black..
You want at least 2 sticks of RAM.
Your budget starts to touch AM5 platform:
https://sk.pcpartpicker.com/list/WWQRfy
If you have flexible budget, more white parts could be gotten, here are few other cases to consider:
Montech XR (this one would need more white parts though)
Corsair 3000D AIRFLOW
Montech AIR 1000 PREMIUM
Montech AIR 903 BASE
Montech AIR 903 MAX
Corsair 3000D RGB AIRFLOW
Montech SKY TWO GX
current PC:
