Hourly 100% Packet Loss spikes lasting ten seconds that start 10 Minutes after Booting
5 hours ago, Alex Atkin UK said:It would be strange, as obvious if it was the laptop having issues on WiFi and PC being fine wired, we'd be thinking very differently.
Its certainly a very confusing situation, I'd say maybe the CAT 8 cable is not great and somehow picking up interference (as none of the cables higher than CAT 6a are really trustworthy IMO), but I can't imagine it causing this particular issue.
I'm not beyond blaming Windows network stack as I've had some very odd issues with it over the last ten years or so. For example one specific network card I own would crash the network stack entirely under load after a specific Windows Update (and I never knew which one), but is suddenly working fine again years later. Same card in Linux always worked perfectly.
I started uninstalling small batches of software and rebooting and running for an hour. I was working backwards on anything that i could recall had asked for consent to update or where there were installs that had not shown any obvious issues upon install in the last few weeks but could have been the culprits.
Problem has gone away.
Suspects are:
Apple Mobile Support Services installed behind the scenes when itunes updated.
Antares client for autotune pro
Bandcamp DAW
Codemeter runtime kit installed by one of the above two pieces of music software.
Oh and just to make things fun, whilst i was swapping the cabling back into the port after testing the wifi again, i pressed the the flashback bios button with the ethernet cable which resulted in a bunch of motherboard software re-installs.
God tech can be frustrating somedays
Thanks for peoples answers in trying to help. No idea why any of those bits of software would do what they did and if i am being honest i am mainly looking at Apple as the main suspect given its the only possible common piece of software that would likely have existed on my pc nine months ago when this last happened when i thought it was norton.
