Audio popping with ryzen 5500
Solved by LOST TALE,
increasing soc voltage to 1.150v in latest bios fixed it. I tried older compatible bios's reducing pci speeds, vddd voltage, etc even disabling hd audio but the one thing that did it is icnreasing infinity fabric voltage. I can now try to lower it but the problem is resolved. It's been like 84h now without an issue and I rolled back all other fixes leaving only this soc voltage increase (which wasn't good enough by itself, u need to select amd overclocking for soc, then select soc voltage again and not vddp)
