Not sure what to get for motherboard upgrade
I'm trying to get a motherboard upgrade not sure what to get
I think I use micro atx case
I have a ryzen 5 7600x
7900 gre
2x ddr5
1 TB ssd
wifi included if possible
What kind of motherboard you're currently use?
Based on your specs, it seems you're on AM5 platform
And may I know the reason of motherboard upgrade?
AM5 is barely 2 years of platform, so it's quite strange to have a upgrade
My System: Ryzen 7800X3D // Gigabyte B650 AORUS ELITE AX // 32GB 6000MHz DDR5 Silicon Power Zenith CL30 // Sapphire Pulse AMD Radeon RX 7900 XT OC with mod heatsink on the metal plate  // Phanteks P300A  // Gigabyte Aorus GEN4 7300 PCIE 4.0 NVME // Kingston NV2 Gen4 PCIE 4.0 NVME //
Seasonic Focus GX-850 Fully Modular // Thermalright Frost Spirit 140 Black V3 // Phanteks M25 140mm // Display: Bezel 32MD845 V2 QHD // Keychron K8 Pro (Mod: Gateron black box ink; Tape mode on PCB and Keycaps) // Razer Cobra Wired Mouse // Audio Technica M50X Headphone // Sennheiser HD 650 // Genius SP-HF180 USB Speaker //
And Laptop Acer Nitro 5 AN515-45 for mobility
Phone:
iPhone 11 (with battery replaced instead of buying new phone for long term and not submitting (fully) to Apple Lord
Well my friend got me a pre built pc a year ago and my pc shuts off randomly and some of the ports are very loose, so the things I plug in disconnects, so I thought might as well get a new one
I see, PC shut off randomly is still a lot of variable of cause, is it during gameplay or just plain browse/video watching/work related?
Regarding of the port loose, that is very strange, it could be a very cheap board such as A620 (although I never used A620, so I may be wrong)
Could you send a video of trying to plug a connector (USB or anything at the rear side of your PC)?
It could be as you suggest a bad board or perhaps the board is not installed properly on the PC case
Phone:
oh umm. my friend said he already bought me a new one, sorry for the trouble
